January 09, 2009, 06:30:09 AM
| | |-+  trunk w/ fuel system inside topic
Author Topic: trunk w/ fuel system inside topic  (Read 375 times)
64dartsb
« on: December 02, 2007, 05:11:44 PM »
I had a post on here a little while back and I don't know why but it won't let me reply to it.
http://www.bigblockdart.com/index.php/topic,24295.0.html
 I mentioned putting my fuel system and pumps and everything inside the car instead of letting the sump hang out with the pumps out side.
Looks like I'm not the only one.....
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3983999&an=0&page=8#Post3983999
My setup looks almost exactly like the one 3/4th of the way down,  the white one.  i ended up just doing U shaped pedestools for the fuel cell to sit on just like his, then I made brackets to hold the pumps and everything, once I'm finished ( a week or so)  I'll post some pictures
-64dartsb
64 dart stock appearing, grocery getter, 360 2.02 in, 1.60 ex victor jr, aeromotive fuel system. msd dist, coil, wires, 6a, 125 shot of nitrous hedman 1 7/8 fenderwells 3 in exhaust  / 904 quarter stick, reverse manual,  /  8 3/4 3.91, suregrip
Re: trunk w/ fuel system inside topic
« Reply #1 on: December 03, 2007, 12:47:36 AM »
hey there.
wedgie
« Reply #2 on: December 03, 2007, 07:30:33 PM »
I doubt that you could ever pass any safety inspection with your proposed setup. In case of an accident, you wouldn't be a very happy camper with gasoline in the cab area. I guess if you completely sealed the trunk from the passenger area it may be OK. Ever see the old photos of Pintos getting rear ended? Be safe and do it right.
64dartsb
« Reply #3 on: December 03, 2007, 11:17:49 PM »
It will be held down by straps just like the ones that summit sells for fuel cells, the car will have a firewall to completely seal off the trunk
« Reply #4 on: December 04, 2007, 10:17:15 PM »
I just had a perfect example of why it would be a bad idea to mount the fuel system in the trunk (exception to the cell):  I ordered a new Holley HP-125 billet fuel pump and due to a manufacturing flaw the thing pumped fuel out through the weep hole at the motor assembly.  Had it been in the trunk, I may have never caught the leak before the fuel would have entered the motor/brush area of the pump and caught fire.
According to Holley tech support, that weep hole is there to prevent fuel from getting to the motor housing in the event that the pump fails.  Looks like it worked this time.  Jegs sent me a new pump, just arrived today.  Hope it works better than the first one!!!
If you really want the pump to be up that high in the fuel system, you could build a raised floor around the pump so in the event of a leak it would still leak to the ground and not in the car.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
tophat
« Reply #5 on: December 04, 2007, 10:32:00 PM »
Ever been to a demolition derby? 99% of those cars run a plastic boat tank where the back seat used to be. Personally, my 63 Dart (street car) has a 6 gallon boat tank in the trunk held in with a ratchet strap Shocked though I do have a vented cap with the hose run out the back. Ever seen a 61~71 Dodge pick up? The tank is right behind the seat.
BTW Pintos blew up because the government WANTED them to. The feds had a grudge against ford and it was their way of getting even. The "approved " fix was a roughly 18" by 6" piece of plastic, thats it. It was very very rare for a pinto to blow up outside of a test facility. The Pinto was one of the best cars ford ever built. Not that I am a ford fan (I'm not) but I would have another early Pinto in a second.
TopHat
64dartsb
« Reply #6 on: December 04, 2007, 10:35:11 PM »
sounds like nobody likes the Idea of the pumps in the trunk.  I just finished it today and everything look really good.  I ended up putitng the pumps on opposite sides so the whole thing looks symetrical.  I'm really happy with everything but the straps, I'm going to redo those next time I get dirty.  I'll post some pictures up in the next few days.
« Reply #7 on: December 05, 2007, 05:37:15 PM »
TopHat
True, but demo derby cars don't generally have to be concerned with going upside down at high speed like a street car would.   explode
The fuel tank in the truck cab design was just a plain poor design from a safety standpoint.  Take a hard hit to the cab side and you could be bathing in gasoline.  How many of those old trucks smelled like gasoline inside the cab!!??
I'm not saying that either way is the correct way to plumb the fuel system, just that there are pro's and con's to both ways.  I would at least weld in a metal bulkhead behind the rear seat and seam seal it for safety reasons.
Doesn't NHRA require a metal bulkhead be placed between the trunk and the main  passenger compartment if running a fuel cell in the trunk?
« Reply #8 on: December 05, 2007, 06:04:05 PM »
TopHat
Yes
