September 07, 2008, 02:02:42 AM
| | |-+  Proform Roller Rockers FYI
Author Topic: Proform Roller Rockers FYI  (Read 316 times)
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« on: February 16, 2006, 05:15:31 PM »
Not sure if anyone is running or plan on running the Proform Roller Rockers, but I just noticed that the latest Mancini flyer has a note about them that they are NOT reccomended for cams with lifts over .484"....Wish I had known that, mine is .510"....Anyone need a set of pretty blue roller rockers? Last time I'll cheap out on parts... hammer
Dr. Hunter S. Thompson
StripeHOG
Greentown, IN
Re: Proform Roller Rockers FYI
« Reply #1 on: February 16, 2006, 05:40:29 PM »
there the only one's that tell you that too Jeg's and Summit say nothing  thank you mancini racing
Andrew Brough
372Z 69 Dart GTS bbd sign
1.46 60' 7.06 95mph so far
Ryan (Strange246)
Merrimack NH
« Reply #2 on: February 16, 2006, 05:54:04 PM »
Yeah how nice, I actually called Summit when I ordered those and asked if they had any complaints etc about them "Oh no sir, they're a very popular alternative to Crane's" .....Maybe the guy was a chebby tech guy LOL
moparteacher
« Reply #3 on: February 16, 2006, 06:42:22 PM »
I don't think you'll have any problems with .510 lift on these rockers. There's not a whole lotta difference between .484 and .510. I would run them. Just make sure you have a good oiling system and springs that are not overkill. Do the springs match the cam? If so, I think you'll be find. Mancini is probably playing it safe to avoid combacks from customers building higher rpm, higher rocker load engines. I don't think you'll find a whole lotta difference beween the Mopar Performance rockers, Dove rockers, and the Proform rockers.
Moparteacher
Moparteacher
Ryan (Strange246)
Merrimack NH
« Reply #4 on: February 16, 2006, 06:58:26 PM »
Moparteacher
You may be right but with close to $7k in the motor I'm not going to risk it...I'd hate to be wrong and have them break at 5-6,000 rpm...
bentwheel43
« Reply #5 on: February 16, 2006, 07:39:39 PM »
I ran them with .501"/.501"  282*/292* with solid flat,6.92 1/8 mile they did good.The only thing the roller is small and I wish the plylocks were bigger&harder.WE didn't brake one ,when I took them off they looked new.My friend has crane gold it the same size plylock,he broke one(plylock) he called jegs to get some they toll him use ARP ones. Make sure you have about 3 or 4 theads showing.We shift at 5800rpm the Proform or the Crane gold don't have rollerbearing on the shaft and the same size plylocks. \/][ Maybe the steel is a better grade.The spring pressure is something to think about ,we both had comp 911 springs.Mine was .501" and his .509",his was a crane broke 1 lock, not like the bottom like in the hotrod mag. in over 5 years. The Proform was run hard 2 years drinks .Make sure the oil holes and pointing  at the valves.  LOL you are like my Mother worryed about s--t before it happens. drinks   GOOD LUCK ,     BENT
section 8 racing , we're nuts about racing"""'
vitamindart
« Reply #6 on: February 16, 2006, 10:54:07 PM »
no i'm with ya ryan i cheaped out a couple years back thought the valves in my indy heads where ok  the machine shop even said they should be fine not even 50 miles later one broke and trashed my engine from now on i'll spend a little more not and save a lot later
Tubbed440
Suspension NinJa
« Reply #7 on: February 17, 2006, 09:52:50 AM »
So stock Indy valves are junk?HuhHuh  Inquiring minds want to know.
And as far as the rocker issue goes, I have been running Harland sharps for about 7 years now.  Some have had trouble, but I have had none.  I only run solid flat tappet cams though......
bentwheel43
« Reply #8 on: February 17, 2006, 08:36:03 PM »
I here if you didn't seat the keepers by tapping them a little with a hammer they mite come off at about 50 miles drinks
440turner
« Reply #9 on: February 17, 2006, 09:55:21 PM »
    I ran those garbage roller rockers in my newly rebuilt engine w/a .557 mech. cam and within 10 mles I busted one in half (rocker shaft hole),wich bent its pushrod throwing it into its neighbor and bending it. I took them back to mancini and got the ductile cranes and never had a problem since. lesson learned.......cheap aluminum roller rockers are not were you want to go
sycboi
Huron, Ohio
bgpoppahall sycboi bgpoppahall
« Reply #10 on: February 17, 2006, 10:04:39 PM »
My nephew screwed at least 2 of those rockers up just sitting in the driveway...the engine never made it on the street with them...
SuperBeast
'70 Dart
Roller 383 w/ much aluminum
Viper T-56, StreetTwin, hydraulic throwout, HD Dana 60, AlterKtion
An enforcer for the Mopar Mafia!
bentwheel43
« Reply #11 on: February 18, 2006, 12:29:17 AM »
how much spring pressure? with .557 cam
