January 09, 2009, 05:50:01 AM
| | |-+  fuel cell in trunk
Author Topic: fuel cell in trunk  (Read 418 times)
67barracuda
fuel cell in trunk
« on: December 05, 2007, 12:21:12 PM »
What are the rules on putting the fuel cell in the trunk of the car for drag racing. How thick was the aluminum you use to seal  the trunk form the drive. Also any pics in a fastback
uwee440
Tolland,CT.
Re: fuel cell in trunk
« Reply #1 on: December 05, 2007, 03:48:34 PM »
I used some fairly thin(sorry can't remember the thickness) aluminum for the  block off from the trunk area,never had any tech guys question the thickness of it,and i cut out the spare tire area for the cell to be mounted.
Ray Barton Racing Engines
« Reply #2 on: December 08, 2007, 04:01:13 PM »
If I remember correctly it was a minimum of 0.030". I'm in a B body so my pic's won't be of much use but here it is just in case.
67barracuda
« Reply #3 on: December 10, 2007, 08:22:30 AM »
Thanks  for the info
67 dartgts
Go fast or go Home
« Reply #4 on: December 10, 2007, 11:33:17 PM »
Hello:
  Here is my setup 5 gallon cell Barry Grant pump, Braided line to front attached to Radiator support curves back to fuel regulator which is mounted on inner fender, feeding Competion Dominator.
  Maynard
