January 09, 2009, 07:13:26 AM
| | |-+  bubble in paint
Author Topic: bubble in paint  (Read 551 times)
mopardart71
bubble in paint
« on: December 06, 2007, 11:02:13 PM »
i just bought a dart with newer paint and it has a few bubbles with a crack in them.what is the best way to fix? maybe heat it up ?touch up paint?the biggest is like 3 inches other 2 are like an inch.thanks
ski
Re: bubble in paint
« Reply #1 on: December 06, 2007, 11:13:27 PM »
It doesn't sound good.  Once you start messing with it you'll have to go all the way.  Is it a color that you can easily get matched?
rjsjea
ProTouring Demon
Re: bubble in paint
« Reply #2 on: December 07, 2007, 12:21:20 AM »
Prob rust and or filler crackin.......ski is right, it may turn out to be a lot of work.  Depends on the quality of the work and materials used.  The right way to fix it is remove whatever is causing the paint to "bubble" and repaint it
Demon:,6.1HEMI, AlterK,Tri4link,custom cage,pro-touring-built for the curves....not much hasnt been modified
mopardart71
Re: bubble in paint
« Reply #3 on: December 07, 2007, 01:56:01 AM »
that sucks the only reason i bought it was because it had good paint turns out that wasnt true.as for the color i think its petty blue,gtxperiences knows i bought it from him.
rjsjea
ProTouring Demon
Re: bubble in paint
« Reply #4 on: December 07, 2007, 11:12:19 AM »
A pic may help..... Undecided
jp260z
Re: bubble in paint
« Reply #5 on: December 10, 2007, 09:48:43 AM »
Bubbles that large are typically either rust or filler cracking - I would probably just drive it this way until the bubbles get worse first - then do it over. There really aren't any quick fixes for that.
Dallas, TX
Re: bubble in paint
« Reply #6 on: December 10, 2007, 10:22:27 AM »
How old is the paint?
All hope is not lost. You can get a paint supply to computer match the paint.
Two things you can do.
1. You can wait to see what happens, if it gets bigger, its rust.
2. Take an active approach. You have to do some damage to repair it. Take an exacto knife and carefully cut at the edge of the bubble to remove it whole to find out what is causing the bubble. If its just simply a delamination or contamination below, clean it, prep it, tape around it, you can use an airbrush to spot paint that area. A small repair can be blended in, it will look better than a bubble. But first step is to figure out what caused it.
mopardart71
Re: bubble in paint
« Reply #7 on: December 19, 2007, 02:28:13 AM »
great,i washed the car today and look at the roof there is like 100 little bubbles in the paint it looks like drips but im not sure yet..........
Dallas, TX
Re: bubble in paint
« Reply #8 on: December 19, 2007, 08:59:38 AM »
Leave it in the sun and see if they shrink. If they do, then it might be a problem with the clearcoat, but most likely is some kind of solvent/contamination issue. Probably not not rust, but you will have to strip all the paint off and repaint. Sorry for the bad news.  Sad
mopardart71
Re: bubble in paint
« Reply #9 on: December 19, 2007, 08:47:39 PM »
graet i spend $1750 for a car thtas got new paint,and it turns out it needs to be repainted,bull sh%t,words of advise never trust or buy a car on the internet people dont like to give you all the info,and then they are gonna say well i did tell you that witch is yet another lie,and the worst thing is is that i still have to pay him $250 for it to get the pink slip, should have passed it on damn.
mopardart71
Re: bubble in paint
« Reply #10 on: December 19, 2007, 08:50:25 PM »
ok i ment ive given him $1500,i still need to pay the $250
440valiant
Re: bubble in paint
« Reply #11 on: December 22, 2007, 09:47:54 PM »
i have the exact same problem as you, i painted my car about 6 months ago, took it to the Langley cruise inn, and now theres about litterally 300-600 little bubbles all over the car. IM dreading sanding off all my beuatifull paint
Mopar!!!!!!!!
dartcharger_270
Re: bubble in paint
« Reply #12 on: December 23, 2007, 12:11:20 AM »
Yeah, never buy a car without seeing it first...I've made that mistake and won't ever do it again.
1965 Dodge Dart 270 HT
1965 Dodge Dart 270 Wagon
eldubb440
Go Phillies!
eldubb440
Re: bubble in paint
« Reply #13 on: December 23, 2007, 12:20:23 AM »
2000 for an old car with a quality paint job?  no such animal. be happy if it runs
mopardart71
Re: bubble in paint
« Reply #14 on: December 24, 2007, 05:44:50 PM »
its a rolling shell
