vancamp
VanCamps Paintless Dent Repair
Here are a few pics of a truck dana 60 I am modifying for car use first is what i started with
vancamp
here I have added a 1" block gound to fit and welded and tapped
vancamp
here is both sides in place and semi finished
vancamp
side view
vancamp
with junk snubber that I used as pattern mounted
vancamp
Nice work.
Thanks I picked this housing up cheap and thought I would play with it a little i still need to do some more finshing around the welds and get the car ends on.
That looks good.
mopartranman
vancamp
How did you weld the iron?
Actually its made of cast steel its not that hard to weld.
Tubbed440
What did you use to weld that with? Stick welder and nickle rod?? Looks sharp man, you did a real good job.
'74 Challenger, Full cage, 500 inch Wedge, 4L80E, ladder bars, Coil-overs - 325/50/15 MT drag radials - Street Car!
AA-slingshot
looks good.....what are your plans to repair the distortion in the bearing bores from welding?
vancamp
there really shouldnt be any distortion as thick as the housing is and no hotter than I got it during welding, I did not weld solid all the way around all at once, I did a little at a time, I got the idea to do this from a rear end builder so hopefully all is well, if not i have hardly anything invested in it yet so we will see.
yeah, i was thinking about th edistortion on the machined surfaces myself. it is a good idea though, any heat from welding can do damage.
68GTconvert
Looks good.
74swinger
You said this was a truck rear? 3/4 ton with full floating axles? Are the axle tubes 3-1/8" OD? What year of truck (I assume many)? I am looking at using a junker DANA 60, but car ones are just stupid (expensive  ). I can weld, so I thought I could modify a DANA instead of worrying about an 8-3/4. Any comments from anyone who has chopped a truck rear before?
Lars
You could always use a truck Dana with cal-tracks and mono-leafs. No snubber to worry about.
Vancamp: Looks good!
demon340v
very nice job thus far, keep at it
ta3834bbl
What happened to the pics? Why were they deleted? I have considered this mod myself.
I am building a 68 cuda from a shell. Might make a Formula S or hemi look-a-like. 383 powered, 727 or 4spd , and 4.30 geared 8-3/4. Front disk conversion done with volare parts and home modified upper control arms. Rear disks next using parts of 96 Grand Cherokee 4x4.
demon340v
yeah where did the pics run off to?
vancamp
Dont know, it says attachment deleted by administration
demon340v
weak sauce, i wonder what did happen, oh unless did you upload them to teh site to host? i know about a few days back the image gallery was full, maybe they delted alot of the images?
69satelite
I want to do the same thing for my valiant could you send me pics since the admin deleted all of yours
blasphemous
Even though this is an old thread, I'd be interested in seeing the pictures as well.
