Topic: Quicktime bellhousings (Read 4872 times)
sycboi
I received my QuickTime bell today. I purchased it thru Phil (66DDart). I suggest if you are in the market to go thru him as well.
This thing is a beefy monster. I have an older Ansen in my car now on my 18-spline A833 and it IS the baddest bell I've ever seen, but this new QuickTime is a close second! So strong and about half the weight of the Ansen to boot...
-Michael
rjsjea
sycboi,
that bell need any spacer/adapter's for the t56?? or does it come with it??
sycboi
sycboi,
It's custom made to bolt the Viper T-56 directly to the big block Mopar engine! -Michael
Tom Q
In the small block application with an 833...all the stock hardware lines up-ie bell crank, rod, fork etc  ? Is this a true bolt in product???
fstfish66
well glad you recieved your T56 viper bell,, mine is who knows where,,was told it was snowed in,, now im being told its on back order,, it wasnt on back order when i sent my money,, but some how QUICK TIME is giving phil the run around,,,bad pratice telling people that there is a batch comming that week and then tell then they are snowed in and cant ship,, then tell you they are on back order,,, im glad im not in a hurry,, and im sure phil is doing all he can to find out when and why,,,
1966 barracuda blown 340 4 speed tubbed 33x22 1940 dodge street rod hemi with A/C 2002 cummins ram dailey driver
dartcharger_270
got my 4 speed big block bellhousing last week, it looks great. And appears that it will clear the firewall much better in my '65 Dart.
1965 Dodge Dart 270 HT 1965 Dodge Dart 270 Wagon
az426hemi
Dartcharger, When do you plan on mocking up your engine/trans? Would like to hear how well that scattershield fits.
Thanks, Mike
dartcharger_270
Mockup will be done within the next month. I'm hoping the bellhousing will be able to bolt in with no firewall/tunnel issues.
az426hemi
Be sure to keep us posted.
Thanks, Mike
fstfish66
i was the first one to order a bell housing,and im still waiting,,wass told the trans mounting plates were welded on upside down,,, a month later i still dont have a bell,,
fstfish66
welll i finally recieved my scatter shield QUICK TIME sb mopar to tremec TKO ford pattern,,,havent opened the box yet,,but its here yiiipppeeeee
viperkota
any updates on this?
fstfish66
no updates on my project at the moment,
Bill_Reilly
I just got 3 of the 6spd to bigblock bells - these things are really nice. And small - they'll make the tunnel mods far easier since they'll clear in the flared area of the tunnel. Looks like I'll just have to raise the center portion of the tunnel, from the seam back.
fstfish66
bill kool..they do appear to have much more clearance,, then any other scater shields including my ansen,,but just passing this along to you,, i have not checked my bell,, but was told or warned,,,depending how you look at it,, to check the trans mounting plate,,face of the plate ,to see if they are square,, level,,from one side to the other,, some one at a major tremec supplier passed it on to me,, my tremec conversation is currently at a stand stil till winter,,,let me know if you find any out of spec,, i have no clue if this info is correct,, it was passed on to me,,don
64'5speed
I'm planning on running one when I do my 360 swap. anyone have a preferred retailer? only place I've found is Keislerauto. I'm not a fan of giving them my money.
fstfish66
you cAN buy quick time bells from PHILDDART he is on this site,, or go to quick times web site they have a list of dealers,,one may be closer to you,,, but i bought mine thru phil good guy to deal with,,
