Topic: You ain't gonna believe this!!! (Read 836 times)
MoparManicMechanic
I'm the one with the metal flakes in the oil after 6 changes... Well I did some investigating and found the cause... You'll never guess, so I had to tell you. the ding bat  who powder coated my engine, did it after the engine was fully assembled, minus intake and exhaust, then baked it! Didn't tell me he did it this way, I had to figure out what the hell could have happened and asked! Apparently the baking process burned off all the assembly lube and the motor was toast from the first crank~!~  !~!!!! I am  Now I don't know if I should trust him to do it again or just go somewhere else  !!! If ya want something done right ya gotta do it yer self! Betcha never would have guessed!!! Bob
65bcuda
I think you are due a refund, and definatly go elsewhere.
67Dart383
He didn't have anof common sense ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) , to tape off those openings !  Sorry Man! I know ya Mad!
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.77@112.97mph
dart4406
Find Yo Self Another Powder Coater!
Home Of Bill Stiles Performance--Jere Stahl Headers And Dave Strickler--"The Old Reliable"
375InStroke
What temp. is powder coating cooked at? Who wouldn't think that would do something to the oil?
mark8denny
A powdercoat oven gets HOT !! it's close to 400 degrees !!! man that sux ! but why did the powder coater have a complete engine ? I had my Harley cyllinders powdercoated before I had them bored. That heat is No good for oil on machined surfaces. Man that sux  That powdercoater should have told you he was going to cook your motor in a flippin oven to cure the stupid powder , what a effin dumbass !  did you bring him a complete motor or did he assemble it too ? maybe he built it wrong as well ?
Rides : 1969 Barracuda hardtop 1967 Sunbeam Alpine 1994 Lincoln Mark 8 , 355 RWHP 2003 Ford F 150 supercrew
CudaSRT8
Geez, whatever you do, don't take it back to him, the moron. He screwed up royally (shame on him), if you take it BACK to him? (shame on you!!)
my64dart
Hi, Sorry to hear this. I thought bad things only happened to me. I guess not. I know your feeling like this  Good Luck Jim
Get a good lawyer. Also find a new powder coat guy.
Cary Snyder 5.7L Hemi Cuda
Umm...my question is...why on earth would you give an assembled engine to a powder coater? All powder coating is baked on, if you gave him a complete engine, its your fault. If he is not an engine builder, then there is no chance in hell you are ever going to get any money back. Sorry, but its not his fault.
MyCreation68
yeah I gotta agree with flyboy. if you gave him a complete engine to powdercoat the assembly lube baking off is your own fault.
Teach a child to be polite and courteous and, when he grows up, he'll never be able to merge his car onto the freeway. -98 Dodge Ram SS/T 5.9L auto all stock -92 Dodge Power Ram W250 5.9L CTD 5spd 4x4 -68 Dodge Dart GT 6cyl auto buckets console work in progress -46 Fargo
He must have had an engine builder send it out. Still very strange.
dusterdarryl
Umm...my question is...why on earth would you give an assembled engine to a powder coater? All powder coating is baked on, if you gave him a complete engine, its your fault. If he is not an engine builder, then there is no chance in hell you are ever going to get any money back. Sorry, but its not his fault.   if thats the case here
A13Dart
400 degrees sent all of the assembly lube right into the oil pan. Baked all the gaskets and sealers pretty well too. I get worried if the temp gauge goes over 200 degrees on an engine.
illfish
Yeah, that motor is probably smoked. That temperature would have taken out gaskets and seals. Sorry for your troubles.
Ciscodog
Spray paint works good.
Goof and Goofier today on Trucks! said, '... that the common mistake folks make is that powder coating is done at 400 degrees. The coating starts to flow when the metal is at 400 degrees...' If that's true, for a block and haeds, assembled, that's quite hot. Any rubber seal could easily be damagedfrom that. Open valves won't hurt it, nor would the heads being open unless they sprayed the powder in the holes... sorry, I forgot the intelligence ratio wasn't that high at this particular shop.  I feel for ya, believe me I do. I like the 'pay through the nose or bleed through it' scenario.
