Topic: compact & lightweight power brakes? (Read 329 times)
BIGFISH
what have you seen used as a compact and lightweight option for power brakes?
'64 Barracuda, 360, 4spd, 8-3/4.....lots of stuff done, but alot still to do
BBLM23
Uhh, manual brakes....
Walter 1981 Dodge Aries 451 B1/BS Best 1/4 9.871 at 136.01mph 1969 Dart Swinger 431 B1/BS Best 1/4 10.649 at 126.45mph Racing Pro in street trim. 1981 Plymouth Reliant 400 http://bbdart.com/parts/parts.html
MikeR
Bones
I swapped the Demon over to modern Mopar aluminum master cylinder. It's really light weight and semi compact. I am running non power though. I saw something called Hydroboost or something like that in a street rod mag a while back that was really small and worked like a booster between the master cylinder and the fire wall.
Anyone can restore a car, it takes a real man to cut one up.
sr71mopar
Hydroboost is powered by the power steering pump. Usually see it on heavy pickup truck and diesel engines.
BIGFISH
you came up with that all by yourself?
BIGFISH
i thought i had seen a racecar version constructed of aluminum and was curious if anyone knew of the company or a source for them. i think i might rework the position of the mastercylinder on the pedal to lower the pedal effort a little.
