November 23, 2008, 07:08:02 AM
| | |-+  RMS rear with sway bar
Author Topic: RMS rear with sway bar  (Read 534 times)
Boxer
« on: December 18, 2007, 11:43:14 AM »
just got my rear sway bar installed with the RMS rear suspension, here's a few pics
Allentown, PA
Re: RMS rear with sway bar
« Reply #1 on: December 18, 2007, 04:36:22 PM »
that is awesome .... where did you get the bar from ?  bbd sign
Bill_Reilly
Administrator
White Haven, PA
« Reply #2 on: December 18, 2007, 04:38:20 PM »
Nice looking install Smiley
Ft. Worth TX.
« Reply #3 on: December 18, 2007, 05:00:14 PM »
Is there a need for this?
Cary Snyder
5.7L Hemi Cuda
rjsjea
ProTouring Demon
« Reply #4 on: December 18, 2007, 06:11:32 PM »
Everytime I see that system..... cat fight....I wish Bill had it out when my rear suspension was done
ilabodyguy
Do Something...Even if it's Wrong
« Reply #5 on: December 18, 2007, 06:18:13 PM »
I love this rear setup. Has Bill or anyone else pondered this setup with the lower bar mounted inboard, directly under the frame rail? Would it work? haven't seen a good enough photo in that region of the chassis to tell if there is enough room for bar mounting and suspension movement. Whadday ya think?
Tacfire11
tacfire11@msn.com
« Reply #6 on: December 18, 2007, 09:20:02 PM »
LOVE THE HEMI  bbd sign
cu440da
Saint Paul, MN
« Reply #7 on: December 19, 2007, 12:21:11 AM »
 It's my understanding Bill designed it to work both ways, stock and inboarded.
'67 Notchback- 12.85 @ 109mph
Boxer
« Reply #8 on: December 19, 2007, 08:13:42 AM »
Bakaruda, as far as I understand, the sway bar is needed for cars running in the tens, it helps take the twist out and plant the tires squarley to the ground.  I got the bar from a local race shop, not sure of the brand, I could get it if you would like.  ilabodyguy; as far as I know it can be mounted either way.
Bill_Reilly
Administrator
White Haven, PA
« Reply #9 on: December 19, 2007, 08:47:11 AM »
Yea, it can be mounted either way without a problem.
ilabodyguy
« Reply #10 on: December 19, 2007, 05:00:40 PM »
If you want to mount the lower bar in line with the frame rail, would a special box with studs pressed into in have to be made and welded into the frame? I'm trying to figure out exactly how you could attach the four fasteners in the lower bar front mount and be able to remove them. Is bill making this type of frame rail mount or am I missing the boat completely. Has anyone done an inboard mount with the tri four setup? I'd love to see some good photos of that. That sway bar setup looks Bad Ass...BTW
abodyjoe
South Jersey...
abodyjoe
« Reply #11 on: December 19, 2007, 07:50:28 PM »
  its just like moving the springs in to mini tub...    http://www.bigblockdart.com/techpages/springs.shtml
ilabodyguy
« Reply #12 on: December 19, 2007, 08:01:39 PM »
Maybe I'm just thinking it would be nice to use Bill's front bracket because of the choice of mounting holes. I suppose that could be accomplished with a weld in box also?
Ft. Worth TX.
« Reply #13 on: December 19, 2007, 08:09:17 PM »
Thanks Boxer. I am not going to run in the tens. Just in the 150mph range.
Cary Snyder
5.7L Hemi Cuda
abodyjoe
South Jersey...
abodyjoe
« Reply #14 on: December 19, 2007, 08:37:43 PM »
  you just need to drill two holes in the same spots at bills brackets..  not hard and just as easy.
ilabodyguy
« Reply #15 on: December 19, 2007, 09:32:31 PM »
Yeah, I don't know why I got so stuck on using the provided bracket. I just love the whole concept of this rear suspension, and with the sway bar in the mix would seemingly provide a fantastic compromise between driveability and bad ass traction. Can't wait for some of the guys with this setup to get to the track and comment on traction as well as traction on the street with the sway bar.
abodyjoe
South Jersey...
abodyjoe
« Reply #16 on: December 19, 2007, 10:06:40 PM »
it improved my 60' at the track...   brought the front tire up higher too..
ilabodyguy
« Reply #17 on: December 19, 2007, 10:13:35 PM »
Are you thinking about adding the sway bar too? It just seems to compliment the idea behind the suspension so nicely. Especially from a traction stand point.
abodyjoe
South Jersey...
abodyjoe
« Reply #18 on: December 19, 2007, 10:29:28 PM »
i would love to have a sway bar ..  it wasn't avil. when we put mine in.maybe i'll by one down the road but right now i have to fix my motor the the sway bar is out for now.
Think3205
A work of art in progress...
« Reply #19 on: December 19, 2007, 10:32:53 PM »
very nice! i'm waiting for the RMS rear to come with a sway bar before i buy one...  Grin  Wink
ilabodyguy
« Reply #20 on: December 19, 2007, 10:34:55 PM »
Right on there... Gotta have the power before you can put it to the ground, eh?
Boxer
« Reply #21 on: December 20, 2007, 08:29:45 AM »
The sway bar I used is from Competition Engeneering P/N c2041
