Topic: New 440 source Stealth Heads (Read 12396 times)
268darts
Hey 440source, Do you or I pick the springs on the fully assembled 440source heads? What about shipping? Yeah...I'm a tightwad, and that is a hell of a deal for those heads.
IL.DART340- 4SP
 For post 440source we are all waiting for heads to come out.Thank You for all of your efforts and time spent.
440source
Hey 440source, Do you or I pick the springs on the fully assembled 440source heads? What about shipping? Yeah...I'm a tightwad, and that is a hell of a deal for those heads.  The springs are a heavy duty single spring with damper that we've used up to .600 lift with no problems. They're 1.500OD and 1.08 ID. We have a test motor here right now with a comp 565 lift in it, and it revs to 7000+ with no valve float or missing whatsoever. Of course, if you want to run a bigger spring, you'd just have to get the springs matched to your cam from the cam manufacturer and swap the springs with the ones that come on the heads (a quick and easy job.) We won't know the exact shipping yet (we're having custom packaging made) and it will vary a bit depending on how far from southern california you are, but it's looking like a good estimate is going to be in the $50-$60 range per set. We might also do a package deal, heads and stroker kit for one low price... Just add your block... Also, thanks everyone for the kind words. We appreciate your support!
scott
69 Valiant
I called and talked to someone at the 440 Source . Straight shooter ! Tells the truth about their product. They have my respect for being Honest . I guess the heads will be too small for my application though. I will be spending my dough with Indy for what I will need. I f I decide to do something smaller in the future I will consider using the Stealth heads.
Ace
You've got my interest peaked even more so if it were at all possible!
sr71mopar
They are starting to win me over.
Tejas
'71 Duster, just getting started...
496dart
I called and talked to someone at the 440 Source . Straight shooter ! Tells the truth about their product. They have my respect for being Honest . I guess the heads will be too small for my application though. I will be spending my dough with Indy for what I will need. I f I decide to do something smaller in the future I will consider using the Stealth heads.  stay away from indy....... read the customer reviews here: http://www.bigblockdart.com/index.php/topic,24943.0.html
smallbigblock
I'm even more excited about those heads now. It's great to get info from the source (pun intended)
Thanks for the post 440source.
I should have left it alone
scott
69 Valiant
Thank's 496Dart. I have a set of 440-1 heads built by Marsh Performance on my blower motor. No Indy rockers . They work great ! I would never let Indy assemble them because I know they are not exactly honest . They definitely have hosed people on their port jobs. I will buy another set throughTodd Marsh ,because he makes sure they are fine before they leave his shop. I build wedge motors and the edelbrocks are too small,and I don't like the victor heads. This kind of narrows the buying field for me. Not interested in B-1 heads either. I think it is terrible for a outfit to screw people like that . Take them to court... I won't be buying from pro comp because they won't tell me about their heads for fear of copying them . WoW! How lame is that ? ! If you know of anyone else that is a possibility for Big high flowing head's let me know. Hey! Pro Comp!
268darts
Shippings reasonable, heads + new info = very good, then you sweetin the pot with a low (?) head/stroker package deal? What kinda deal are y'all kickin around there? Balance included? Thanks for the reply.
speedymopars
Hey 440source, Do you or I pick the springs on the fully assembled 440source heads? What about shipping? Yeah...I'm a tightwad, and that is a hell of a deal for those heads.  The springs are a heavy duty single spring with damper that we've used up to .600 lift with no problems. They're 1.500OD and 1.08 ID. We have a test motor here right now with a comp 565 lift in it, and it revs to 7000+ with no valve float or missing whatsoever. Of course, if you want to run a bigger spring, you'd just have to get the springs matched to your cam from the cam manufacturer and swap the springs with the ones that come on the heads (a quick and easy job.) We won't know the exact shipping yet (we're having custom packaging made) and it will vary a bit depending on how far from southern california you are, but it's looking like a good estimate is going to be in the $50-$60 range per set. We might also do a package deal, heads and stroker kit for one low price... Just add your block... Also, thanks everyone for the kind words. We appreciate your support! Hey Brandon, you treat us right, so we treat you right... I still need to send you pics of my KB block based 528 for your website. Find a pic off of the "440source - the journey begins" thread and I'll send you the full size one. I have more with the car, I just need to post. Brian
Pro Street dart
My FBO ignition requires Autolite 85's. They seem to work good. I just saw on the 440 Source heads they require:
"Part No: 138-1000 - Champion Spark Plugs 3/4" extended reach"
Brandon or anyone, can you cross the Champions to Autolite 85 if someone has the incentive & time?
scott
69 Valiant
That's a disgusting pic,but also kinda funny.. Whattaya Mean DRUGS?!!!
'73Dusta
 and  to all that supplied the great info. I too will spend my $$$$$ with 440 source
dare_dude
Brandon did I hear that there will be a change in price after first of year?
440 ValiantCharger
I guess this may happen, the stroker kits has just gone up $100. Pro Street dart those two dudes need an extreme makeover
sr71mopar
It's actually a banjo and a guitar.
383man
I know if the single springs are the same as the Eddy's they will work ok up to .600. We had the stock single springs on the Eddy heads on my boys Dart with the MP .557 cam. They worked fine for 2 years and we decided to change them this year to a dual spring and the car has run the same. So I would say the springs it comes with is fine for a mild street car. If you plan to race alot then just change the springs out. Ron
IL.DART340- 4SP
After the first of the year.That is when they come out.You mean to tell me they are going up before they have even sold a pair yet.
It's actually a banjo and a guitar.  Deliverance is a great movie. The dueling bango part is GREAT. I like the quick shot of the guy whistling @ the 3:09 mark. http://www.youtube.com/watch?v=esl2NNOtHQEThis clip is a blantent Copyright Infringment though. I had that EXACT same station wagon. It was my grandmother's. 390, red interior, looked like it just came off the dealer's lot when I drove it around back in like 88. I put surfboards on the roof rack. Never shoulda sold that car. It's like a cool retro SUV.
440source
After the first of the year.That is when they come out.You mean to tell me they are going up before they have even sold a pair yet.  No, they'll be the same price for at least a few months. Everybody that wants a set will be able to buy them at the $899/pair price.
bigtimeauto
I heard you were coming out with new blocks? Any truth or just a rumour?
Unfortunately their stroker kits went up in price again!
375InStroke
What? Their stroker kits went up $100! That's almost a tank and a half of gas.
