July 05, 2008, 08:34:04 PM
| | |-+  harryhood -= pm box is full - caliper position
Author Topic: harryhood -= pm box is full - caliper position  (Read 104 times)
bbscamp
Ehm.....B5 Blue am I?
« on: December 31, 2007, 08:51:26 AM »
Your mailbox is full.  Re:  calipers to the front or rear:
either way, they work perfectly fine..  Make sure the bleeders on the calipers are on the high side of the housing so that you can bleed them.  I've run them both ways, no issues.  Spindle geometry is the same, so no alignment issues either.  I like to run them to the back side to give more clearance to aftermarket sway bars.  Stock is the caliper to the front.
good luck,  Mike
