Topic: Entire Front Suspension Swap Question (Read 419 times)
ValiantOne
I'm pretty sure I know the answer to this already, but I don't want to go buy a whole car and find out it isn't what I need! So here goes.
Current Car: 1968 Valiant, drum brakes, flat motor mounts, no sway bar, etc.
Found a 1974 Plymouth Duster for sale. It is a /6 car. Should have disc brakes, spool motor mounts and sway bar, Correct? Or is the /6 K not useable?
I have been looking at parts cars where I would get EVERYTHING I need for the front end of the 68. Except the torsion bars of course. I just want to drop the whole K with suspension and everything. Rebuild it. Install my 400 BB on it, and then slide it up under the 68.
Am I barkin' up the right tree here?
Thanks guys
Chris
Disc brakes and a sway bar would have been optional on slant six cars, but it's worth a look. The sway bar can be added so I wouldn't make that a deal breaker.
One more thing, and I've only come across this once, but make sure the k-member isn't broken around the LCA pivot pin hole. It can be fixed, but it would be a pain.
You are not guaranteed a swaybar or large bolt pattern. I would get a 73+ 4 door 318 A/C car for that swap, then you get a V8 Kframe and the heavier torsion bars.
ValiantOne
What about the engine mounts and K member. Will the /6 K work with V8 engine mounts?
Not with factory ones.
ValiantOne
crap! The donor car just became nothing but a front disc conversion.
Maybe I can talk the guy down.
Thanks guys,
Chris
CA Duster 383
Both the /6 K frame and the V8 K frame could be used with Shumacker swap mounts, or use the /6 K frame to add/modify for BB V8 power.
My Duster came with the MP BB K member and a 383 so at least I have a starting point with out having to buy more stuff.
But it was the most expensive project car I have ever started out with.
kendog170
Ive got a Bigblock spool type k frame.No dent or cracks just some surface rust that will beadblast easy enough.I dont have the mounts.You could get those at 44 source.$100 plus shipping if it helps. Kenny 68 GTS Ragtop and currently building 68 500 stroker dart.
 68GTS Ragtop 340 4spd.200K miles and current 500 Stroker project.  It all Started With a Hood
4spdfury
the slant 6 k frame will work with shcumacher motor mounts so its not just a disk brake conversion.
boden
I would bet if it is a slant 6 it is more likely drum brakes and small bolt pattern. You might get lucky though 1 of the 4 73+ slant 6 dusters I have had did have disk brakes.
