December 04, 2008, 12:31:51 AM
| | |-+  Duster coming together after paint...
Pages: 1 2 [3]  All Go Down Print
Author Topic: Duster coming together after paint...  (Read 3246 times)
Duster440
Blasphemous custom Duster
Re: Duster coming together after paint...
« Reply #60 on: March 06, 2008, 06:53:00 PM »
My wife is about to throw my car and me out. madwife
Ha! I'm pretty fortunate to have a very supportive wife through all this.
Had a glass guy come out and install a new windshield and reinstall the back glass today. It was worth it. "Fresh glass" sure is nice. Getting it back in helps it look more like a car. Break-in d-day is just a couple days away.
« Reply #61 on: March 06, 2008, 08:54:35 PM »
how much did the glass guy charge?
i'm gettin a windshield put in but i have to take it down to him Tongue
Duster440
« Reply #62 on: March 06, 2008, 10:04:55 PM »
He's a mobile installer. Charged me $250 installed for the front and another $50 to put my rear glass back in (a little high maybe) - but no tax. I had him urethane the gaskets in to reduce the chance for leaks.
Don't forget to install the trim clips first.
mattsmopars
« Reply #63 on: March 06, 2008, 10:19:27 PM »
Sure is looking sweet! Keep up the good work,and by the way you can't beat a red mopar or blue,or green or well you get the picture you can't beat a MOPAR!  hammer  4 speed
« Reply #64 on: March 06, 2008, 10:24:16 PM »
thats what i'll prob end up paying,i need to find a mobile guy
« Reply #65 on: March 07, 2008, 11:22:27 AM »
looking good, keep the pics coming.
Duster440
Duster coming together after paint... IT'S ALIVE!!!!!
« Reply #66 on: March 09, 2008, 02:25:31 AM »
Here's some video of the fire-up today.
I temporarily bolted the Pype's Race Pro muffs to the ends of Schumacher's using some flex tubing. Basically the equivalent to muffs right on the ends of collectors. Worked great for the break-in. I'll get the exhaust system on proper later.
We stopped it about 10 minutes into the break-in 'cause it was approaching 210'. (Looks like a shroud will be absolutely necessary - or a new radiator setup). Fixed a leaking lower rad hose before resuming. One of the clear sight plugs on my carb broke and just popped off while we were waiting. So, I had to pull the front bowl and remove what was left, then put the sight plugs back in. Weird.
Front pump seal is leaking a little. Started leaking before we even fired it, but I had intentionally overfilled the trans. Don't know yet if it's a permanent leak or just residual oil in the bellhousing. Not looking forward to pulling the trans.
Overall, it went pretty well with no catastrophic failures. Sounds decent too.
http://blip.tv/file/728393/
« Reply #67 on: March 09, 2008, 03:01:19 AM »
 Cool
moparchop
porkchop
« Reply #68 on: March 09, 2008, 07:12:03 PM »
If you dont mind me asking,how bad was the price on the front new windsheild,mine had a little mishap with a hammer.74 goldduster
440goldduster
Duster440
« Reply #69 on: March 09, 2008, 07:47:47 PM »
$250 installed. Mobile installer.
dangerdawg
« Reply #70 on: March 10, 2008, 08:42:37 AM »
looks & sounds good.
DartGTDan
71 Dart GT (1 of 1255)
« Reply #71 on: March 10, 2008, 05:55:38 PM »
Preston,
Awesome looking job!!!  I was wondering if you could snap a picture or two showing how the dash frame is mounted up near the windshield.  Also, did you do the custom dashboard as well?  Or is it one of RMD's products?
thank you
1 of ~1255
Duster440
« Reply #72 on: March 11, 2008, 01:10:51 AM »
Preston,
 thank you
Thanks. It is an RMD insert. Unfortunately, now that the glass is in, it's hard to show how the dash frame is mounted near the windshield. There are 5 screws across the opening just inside of the glass. Your windshield gasket has a lip that hides them on the inside.
About the best I can do is this still from a video clip taken at disassembly.
« Reply #73 on: March 11, 2008, 01:13:55 AM »
Preston,
 thank you
my windshield is out,if that pic doesn't help you tell me what you need and i can snap a pic or two for ya.
x360x64dart
« Reply #74 on: March 12, 2008, 09:51:33 PM »
I'm lookin at geting a rmd insert and was wondering do you have to cut your dash open or does it just fit in front of the existing material?
thanks, Dustin
Duster440
« Reply #75 on: March 12, 2008, 11:47:50 PM »
You remove the cluster and any of the plastic trim (such as the wood-grain panels) if you have them. Some trimming of the metal dash frame is required. The gauges are spread out further so you have to remove material between the exisiting cluster and the radio/heater control openings - in some cases, all of it.
Pages: 1 2 [3]  All Go Up Print
