November 21, 2008, 02:16:55 PM
| | |-+  question about the t-block on rear axles?
Author Topic: question about the t-block on rear axles?  (Read 287 times)
jet-taz
« on: February 19, 2006, 09:48:14 AM »
is the block for the rear brakes the same on a 81/4 & 8 3/4 .the one i took off an 81/4 doesn't have a vent screw and the 8 3/4 didn't have oneon it.i got a vent screw on it's way.but was question the block it's self. thanks jet-taz
dartracer
Strasburg CO.
Re: question about the t-block on rear axles?
« Reply #1 on: February 19, 2006, 10:41:05 AM »
The one that I have on the 81/4 that is going in the fish is a lot bigger than one from an 83/4. I would think you could still use a vented bolt in it.  Dave
qkcuda
Caledonia, ON Canada
« Reply #2 on: February 20, 2006, 08:46:36 AM »
I don't know about the 8 1/4, but the one off my old 7 1/4 bolted right up to my 8 3/4.
jet-taz
« Reply #3 on: February 20, 2006, 08:13:44 PM »
did yours have a vent top? and is the bolt hole in the block the same size?
qkcuda
« Reply #4 on: February 21, 2006, 09:25:31 AM »
Taz, I have the vent top and as far as I can recall, everything from the 7 1/4 fit the 8 3/4, but it was a long time ago when I took it apart. ( and I sometimes have trouble remembering what I did yesterday) Roll Eyes
bbscamp
Ehm.....B5 Blue am I?
« Reply #5 on: February 21, 2006, 03:20:19 PM »
my ole 8.75 used a vented retaining bolt for the brake block, my 8.25 and 7.25 both use a solid bolt, as there is a seperate vent tube attached to the housing as a vent. If you use a vent rather than a solid bolt, it won't hurt things, but don't use a bolt, where a vent it needed.  jUst check your rear for the seperate vent. carefull with the vent-bolt.....then strip often....and use neversieze when installing it.   that way you won't snap it off in the housing next time you need to disconnect it.    Mike
vitamindart
« Reply #6 on: February 21, 2006, 05:35:11 PM »
i thought it was part of the rear hose
jet-taz
« Reply #7 on: February 21, 2006, 06:21:09 PM »
well i got my vent bolt(it's  mopar 04032798) it fits the block from the old rear from the car, but i need to see if the blocks themsleves are the same.
