Topic: 3rd. Generation Hemi/A-Body Stuff (Read 8601 times)
72Scamp
He wants $200 + shipping, I'm going to try to jew him down a little, if he won't go, then I'll probably do it anyway, cause if they don't work, I can prbably get my money back on Ebay. Here's the pic of the other side.  Hope this helps.
Scamp, That sounds like a great deal. Even with shipping, that would be less than ONE brand new one. If you can get them for $200 WITH shipping, you stole them!
Anyway, yeah, those are the ones. Although I'm using (and prefer) long tube headers for this build, I appreciate the more "stock" look too and am real curious if they'll work on an Abody. I'm quite sure they'll clear the frame on both sides. You MAY run into problems with the steering box and column with stock suspension. Also, they MAY dump out right down near the torsion bars and be difficult to run an exhaust pipe from. With an AlterK, I bet they'd be perfect.
Dave Weber, if you're watching, see what I mean about how much more tucked in they are than the LX versions? O.J.
72Scamp
Well, I bought them. $195 for the pair shipped to my door. I can't wait to see how they fit.
I'll keep you informed.
Scamp, you stole them!
So where are you on your build? Do you have the hemi in the car? Are you using stock K or AlterK? Bring us up to date and keep us informed on the manifolds...
72Scamp
Very early in the build. Engine is on a stand. Doing body work/metal replacement. I figure I will bolt on the manifolds and do a test fit with the stock k-frame first. I'll let you know when I get that far.
72Scamp
Thanks for the picture. There is a part # stamped in the top side of the flange. If you can read it, could you post it for reference for everyone. Thanks Dave
Here's the stamped #'s on the flanges: 05037637AC 04722 05037638AC 05215
MauiCuda
Note to Bakaruda, re fuel pump: I'm using a Holley 12-920 in my set-up (5.7L EFI Crate motor in a '68 Barracuda). I am using stock fuel tank, with return line plumbed into fuel-filler neck, down low, near the frame-rail kick-up. The Holley pump is a re-boxed Walbro #CSL392. I think that it is adequate for stock 5.7 only. Looks just like the Bouchillion pump pictured in this discussion. I've heard bad things about Aeromotive, but no personal experience. Aloha
MauiCuda, WELCOME! So glad you found us here at  There's a number of us putting the GenIII Hemi in A-bodies and we're hungry for as much information and pics as we can get (hint, hint). I saw a post of yours somewhere on the internet with one picture, but we sure would like to see as many pictures as you can find the time to post (?) So you have a stock front suspension then? 12.9 - 13.00s surely is not too bad. Your combo sounds pretty good / potent. I suppose a little deeper into the 12's is not too great of expectation. What rear tires are you running at the strip. Is traction the problem? I'll be running a 6.1 / Tremec 5spd. with cam, ported heads, headers and programmable computer. Rear gears will probably be in the area of 3.70 to 4.10 and I'm HOPING this will get me into the 11s. I DO want to run either drag radials or possibly even 9" slicks (NHRA Stock Class slicks) whatever it takes to see what it will actually run. Anyway, again, welcome to the site. We'd really love to have you hang around!
MauiCuda
Reply to CudaSRT8, et al: Rear suspension is super-stock springs and pinion snubber. Tires are M-T "ET Street Radials" P275/50/15. 60' times are all about 2.0 seconds, plus or minus 0.05 seconds, depending on track and my launch "technique".
Different subject: Anybody have any suggestions as to how best to deal with E10 Fuel, with an open-loop engine controller (as supplied with the EFI version of the Mopar crate motor). The crate motor wants 58 psi, usually put the f/pressure regulator to 60psi at the track; I am thinking that 62psi might be better to get the btu/gallon number up to the same as pure gasoline - while at the track. I do have a wideband O2 sensor and readout installed. Usually shows about 12.2:1 A/F ratio at the finish line. Should be 12.0:1? Thanks, David
72Scamp
Just in case anyone is interesed. Here's a picture of the LX car manifold (has been used in Stock suspension a-body, by notching the frame a bit). It's roughly 6.25" to the furthest point out.  This is the SRT8 Jeep Cherokee manifold, it's about 4.25" to the furthest point out from the engine. I haven't tried it in the car yet, so it maight run right into the torsion bar.
USCG Charger
Scamp let us know about the Jeep manifolds.. I have a set that I want to use.
Yeah, the SRT8 Jeep manifold will absolutely clear the fenderwell on the right side. The question is more whether or not it will clear the steering column. Also, if running stock suspension, whether or not they dump right on top of the torsion bar. Another option would be 5.7 Jeep manifolds if somebody didn't care about higher performance. They are still tucked in tighter than LX manifolds and don't dump down as far, so probably not a problem with the torsion bars...
Gocirino, haven't heard from you in a while. How's the build coming. I think the last we heard you'd been able to start it up. Been able to drive it at all yet???
gocirino
Thanks for asking.... I am almost finished wiring and installing the dash, should be putting the interior back in it by the end of the week. The plan is to trailer it to get the front end aligned then a day at the dyno. Then the de-bugging process begins, drive, fix, and adjust everything. So far, driving it around the yard has been a real kick... car has good feel to it. How's your project coming?
gocirino
Finally done putting it together. Still need to get on the dyno for a final tune. Very fast and very nimble. Worth the headaches of building it.
Looks great!!
That radiator from Northern?? 17" wheels, what tire size??
Joe-Dokes
Gorcino,
Other than a few differences, (like body color) you have essentially built the very car I am dreaming of.
Very nice, excellent work. Enjoy.
Regards
Joe Dokes
gocirino
Looks great!!
Radiator is a Northern. Billet Specialities GTX70 (Newstalgiawheels.com) Front: 7x17 (5.25” Backspace) Tires: GoodYear F1GS 225/45 Rear: 9.5x17 (4.5” Backspace)Tires: GoodYear F1GS 285/40 Rearend is a narrowed Strange DANA 60 3.54 (nets me a 4.10 final with the tranny gears) all being held in place by brother Bill's Alterkation traingulated four link.
gocirino
Gorcino,
Regards
Joe Dokes
Thanks Joe...I wish you could drive it sometime. I might paint it B5 Blue in the fall. I just can't get that color out of my head!
golferjohn
I think I'll add my $0.02 worth This  Plus this  and this  and  equals alot of this  and
gocirino
Golferjohn...... that's one bitchin Dart!
Hit em long and straight!
gocirino
75!!!!! Yikes...... out of my league!!! I enjoy watching those great shots. Nothing better than getting on in two and a one putt!
How about we come up with a 6.1 golfcart!
kzcountry
Looks Sweeeeet  Gocirino. I am slowly coming along with my project. hope my 67 will look as good as yours does. Congrats onn a great job.
gocirino
Looks Sweeeeet  Gocirino. I am slowly coming along with my project. hope my 67 will look as good as yours does. Congrats onn a great job.  Anything I can help with let me know... I don't have all the answers but I know where to get them. Good luck with your build..... and thanks to everyone for the nice comments! John
fasbird
Hey guys. I was directed to this site by "rjsjea". There's some good stuff goin' on here.  Here is what I'm thinking of doing. I have a '71 RR. I know...not a A-body, but cut me alittle slack....  ...OK? Anyhow, I have had the AlterKtion setup sitting for a year now still in their boxes. I was going to put my 440-6 back into the car, but with this new MP 6.1 crate kit out, I am seriously thinking of going modern. I have been running the Keisler TKO from '01 til I took the RR apart in mid-'04. I was going to install the Billet Specialties front engine treatment and A/C. Haven't decided of whether it will be Classic or Vintage? I will be watching this thread for all the great feedback and hints. Just wanted to introduce my self. Gary Fast aka; Fasbird
Welcome Gary.....
My motor, motor mounts got here.......my visa card will be burning up this summer for all the parts that are being ordered
-Rob
fasbird
OK, I'm well on my way. Here's an update.
Purchased the 6.1 Hemi crate kit along with TTI headers just for the AlterKtion/6.1 application. Also bought Weldtech's new mid-sump pan and pickup that clears all the modern new K-members out there like RMS, XV, and MF. Also got all needed ordered from Keisler for the hook up. All parts are scheduled to get here in the next couple weeks.
All that remains for now is to come up with a radiator/fan module suitable cooling solution.
kzcountry
Give Dave a call or check him out at http://www.henrycorods.com/. The system is really nice, I saw the set up at the Indy swap meet. I ordered the complete system from Dave, it will be a few months before I am ready to install it.
