Topic: over spray on glass (Read 729 times)
440dstr
i have heavy over spray ect. on all the glass on my dart . is there a polish /cleaner that will work and is safe on glass?
blown71duster
I would try lacquer thinner, if that doesn't cut it then take a razor blade to it,wet the window with a water dish soap solution to help not to scratch it
1971 Duster 440 Single turbo
DO NOT USE A SCOTCHBRITE PAD! I learned the hard way.
Do it with a razor blade. Then clean the glass with that stuff for doing glass stovetops.
extra fine steel wool
dartracer
 steel wool best glass and chrome cleaner out there.
tophat
I used a razor blade with glass cleaner to lubricate it. Worked real well to remove primer form my windows.
TopHat
jwmotors
If you use steel wool make sure you wash the car good when you are done ( it is the best thing to use ) because all the little fibres will rust if you leave it on the surface and they get wet. Trust me , you will be wondering where all the little rust spots came from . Fresh paint is soft and it sticks even worse .
440valiant
razor blade works good
Mopar!!!!!!!!
68S
Use bronze wool, the particles left behind will not rust.
Pat
Extra fine steel wool AND laquer thinner worked wonders. It even removed the hard water deposits that collect in the corners of the rear glass along the weather stripping. Of course this was done with the glass removed. If you use the laquer thinner with the glass in, be advised, the thinner doesn't like rubber products and may tend to dry them out or harden them prematurely. The foamy and hairy/furry/felty weather strips are very susceptible to this and die a horrible seething death from being dried out from the chemical attack.
norwaycharger
Thats the right way to do it
Mopar Tom
Another way that is very safe is what the eyeglass shops recommend is isopropyl alcohol (rubbing) --do not drink !!  I've used it on overspray on my glasses (plastic lenses) --works great ,,,,,just a little elbow grease & a clean cloth/towel -,,,,I love lacquer thinner but it's kinda harsh on the rubber-----------------Mopar Tom
Do it now or forever wish you had !
hemi_jay
how about a mild spray on paint stripper? I havent had this problem before, but it makes sense...
74swinger
Razor blade is best, IMO. Water, soap together make a great lubricant
DartKnight
I use a razor blade and glass tint adhesive remover. Strong glass cleaner works well also.
Jason
mopardart71
i agree windex-razorblade-steelwool-windex-towel=good
speedymopars
Windex and razor blade.
What NOT to use. dimond anything...
