October 10, 2008, 09:45:52 PM
| | |-+  over spray on glass
Author Topic: over spray on glass  (Read 697 times)
440dstr
over spray on glass
« on: January 18, 2008, 11:52:56 PM »
i have heavy over spray ect. on all the glass on my dart . is there a polish /cleaner that will work and is safe on glass?
blown71duster
Re: over spray on glass
« Reply #1 on: January 19, 2008, 12:05:52 AM »
 I would try lacquer thinner, if that doesn't cut it then take a razor blade to it,wet the window with a water dish soap solution to help not to scratch it
1971 Duster 440  Single turbo
« Reply #2 on: January 19, 2008, 12:06:47 AM »
DO NOT USE A SCOTCHBRITE PAD! I learned the hard way.
« Reply #3 on: January 19, 2008, 06:00:37 AM »
Do it with a razor blade. Then clean the glass with that stuff for doing glass stovetops.
Go Phillies!
« Reply #4 on: January 19, 2008, 10:37:33 AM »
extra fine steel wool
dustertogo
« Reply #5 on: January 19, 2008, 10:52:32 AM »
 agree steel wool works good.
dartracer
Strasburg CO.
« Reply #6 on: January 19, 2008, 11:20:51 AM »
 agree steel wool best glass and chrome cleaner out there.
tophat
« Reply #7 on: January 20, 2008, 04:56:15 PM »
I used a razor blade with glass cleaner to lubricate it. Worked real well to remove primer form my windows.
TopHat
jwmotors
« Reply #8 on: January 20, 2008, 05:58:27 PM »
If you use steel wool make sure you wash the car good when you are done ( it is the best thing to use ) because all the little fibres will rust if you leave it on the surface and they get wet. Trust me , you will be wondering where all the little rust spots came from . Fresh paint is soft and it sticks even worse .
440valiant
« Reply #9 on: January 21, 2008, 11:10:07 PM »
razor blade works good
Mopar!!!!!!!!
Go Phillies!
« Reply #10 on: January 21, 2008, 11:14:16 PM »
agree agree agree
68S
« Reply #11 on: January 25, 2008, 01:54:35 AM »
Use bronze wool, the particles left behind will not rust.
Pat
« Reply #12 on: January 25, 2008, 10:00:15 AM »
Extra fine steel wool AND laquer thinner worked wonders. It even removed the hard water deposits that collect in the corners of the rear glass along the weather stripping. Of course this was done with the glass removed. If you use the laquer thinner with the glass in, be advised, the thinner doesn't like rubber products and may tend to dry them out or harden them prematurely. The foamy and hairy/furry/felty weather strips are very susceptible to this and die a horrible seething death from being dried out from the chemical attack.
norwaycharger
« Reply #13 on: January 25, 2008, 11:50:01 AM »
Thats the right way to do it Smiley
AKA, the drummerboy
http://www.pink-division.com
Mopar Tom
Is my car ugly or what?
« Reply #14 on: January 26, 2008, 12:52:07 AM »
Another way that is very safe is what the eyeglass shops recommend is isopropyl alcohol (rubbing) --do not drink !! drinks  I've used it on overspray on my glasses (plastic lenses) --works great ,,,,,just a little elbow grease & a clean cloth/towel -,,,,I love lacquer thinner but it's kinda harsh on the rubber-----------------Mopar Tom
Do it now or forever wish you had !
hemi_jay
Mopar FTW!
« Reply #15 on: January 26, 2008, 03:41:12 AM »
how about a mild spray on paint stripper? I havent had this problem before, but it makes sense...
74swinger
« Reply #16 on: January 26, 2008, 10:26:36 PM »
Razor blade is best, IMO. Water, soap together make a great lubricant   lol
DartKnight
« Reply #17 on: January 26, 2008, 11:05:33 PM »
I use a razor blade and glass tint adhesive remover. Strong glass cleaner works well also.
Jason
mopardart71
« Reply #18 on: February 06, 2008, 03:07:23 AM »
i agree windex-razorblade-steelwool-windex-towel=good
speedymopars
« Reply #19 on: February 07, 2008, 01:27:29 AM »
Windex and razor blade.
What NOT to use. dimond anything...
