Topic: Tubs finished / RMS AIRRIDE rear suspension/Wilwood brakes (Read 2978 times)
MyCreation68
uh oh I need new shorts. beautiful car.
I don't suffer from road rage, I enjoy every minute of it. My vehicles:  -1984 Dodge Ramcharger 318 auto 4x4 atc stock beast -1968 Dodge Dart GT 6cyl auto buckets console work in progress -1966 Bridgestone 90 Deluxe -1946 Fargo 3/4 ton
norwaycharger
NICE!  Those wheels are a perfect match for that car..
Datsbad
The wheels are made by CCW , CCWHEEL.COM . I havent seen any Demons done like this at all .
smallbigblock
 Damn near fell outa my chair
I should have left it alone
MyCreation68
 Damn near fell outa my chair  then my work here is done.
ab7fh
Your pics helped me tremendously. I've been working on one of my tubs for the last two days. I'm finally to the point of re-installing the tub.
I also welded the trunk floor to the frame rail. I just clamped it as I went along to bring the gap together and welded small spots at a time. I only blew threw a couple times and they were small and easily filled.
Up to this point everything is looking great. I just hope I can come close to what you've done with that killer Demon.
ColeMc
I agree this part of the job can be a problem. It's easy to end up with the top edge of the rail so thin that it disappears when you try to weld it. I think the trick is not to get carried away removing the flange and making that edge paper thin. Even if you need to work the top of the rail under the floor slightly. The use of clamps, some light hammer work and being careful with the heat on the welder should help get that seam put together without making a big mess.
x360x64dart
What chemical do you use to clean the "raptor liner" gun when your done spraying. Just regular paint gun cleaner, or something special?
Thanks, Dustin By the way nice ride!
It's almost a big block! Escondido,CA
hemi_jay
Hold the suction tube of the gun in a bottle of thinners then just spray (with air supply) as if you where painting until it looks clean.
x360x64dart
Thanks for the tip with the raptor liner. stuff is awesome and really easy to use. i was wanting to have the bottom of my car rhino linerd but have no way to transport it at the time. perfect solution. looks awesome.
ColeMc
In between all of the other projects underway, we have made some progress on the Demon...  . I informed Datsbad that you were asking and he should update soon with the photos he has. Thanks for asking.
Datsbad
Updating this thread with this Pic. I will start a new thread !
dd69a
absolutly awesome
