October 11, 2008, 05:55:34 AM
| | |-+  Tubs finished / RMS AIRRIDE rear suspension/Wilwood brakes
Pages: 1 2 [3]  All Go Down Print
Author Topic: Tubs finished / RMS AIRRIDE rear suspension/Wilwood brakes  (Read 4209 times)
Re: Tubs finished / RMS AIRRIDE rear suspension/Wilwood brakes
« Reply #60 on: February 02, 2008, 04:03:15 AM »
uh oh I need new shorts. beautiful car.
-46 Fargo
norwaycharger
« Reply #61 on: February 02, 2008, 06:39:23 AM »
NICE! Cool Cool
Those wheels are a perfect match for that car..
AKA, the drummerboy
http://www.pink-division.com
Datsbad
« Reply #62 on: February 02, 2008, 08:08:42 AM »
The wheels are made by CCW , CCWHEEL.COM .
I havent seen any Demons done like this at all .
smallbigblock
« Reply #63 on: February 02, 2008, 11:51:05 AM »
 lol LOL   Damn near fell outa my chair
I should have left it alone
« Reply #64 on: February 02, 2008, 12:00:20 PM »
Grin lol then my work here is done.
-46 Fargo
ab7fh
« Reply #65 on: February 02, 2008, 06:36:47 PM »
Your pics helped me tremendously. I've been working on one of my tubs for the last two days. I'm finally to the point of re-installing the tub.
I also welded the trunk floor to the frame rail. I just clamped it as I went along to bring the gap together and welded small spots at a time. I only blew threw a couple times and they were small and easily filled.
Up to this point everything is looking great. I just hope I can come close to what you've done with that killer Demon.
ColeMc
« Reply #66 on: February 02, 2008, 10:27:23 PM »
I agree this part of the job can be a problem. It's easy to end up with the top edge of the rail so thin that it disappears when you try to weld it.  I think the trick is not to get carried away removing the flange and making that edge paper thin. Even if you need to work the top of the rail under the floor slightly. The use of clamps, some light hammer work and being careful with the heat on the welder should help get that seam put together without making a big mess.
x360x64dart
« Reply #67 on: February 07, 2008, 11:49:38 PM »
What chemical do you use to clean the "raptor liner" gun when your done spraying. Just regular paint gun cleaner, or something special?
Thanks, Dustin   By the way nice ride!
hemi_jay
Mopar FTW!
« Reply #68 on: February 14, 2008, 09:19:59 AM »
Hold the suction tube of the gun in a bottle of thinners then just spray (with air supply)  as if you where painting until it looks clean.
x360x64dart
« Reply #69 on: February 18, 2008, 05:42:00 PM »
Thanks for the tip with the raptor liner. stuff is awesome and really easy to use. i was wanting to have the bottom of my car rhino linerd but have no way to transport it at the time. perfect solution. looks awesome. Cheers
Merrimack NH
strange246 strange2462000
« Reply #70 on: June 06, 2008, 10:14:59 PM »
Awesome Demon! Same color as mine, any updates?
Ryan
Dr. Hunter S. Thompson
ColeMc
« Reply #71 on: June 09, 2008, 07:28:07 PM »
In between all of the other projects underway, we have made some progress on the Demon... motorinstall.  I informed Datsbad that you were asking and he should update soon with the photos he has. Thanks for asking.
Datsbad
« Reply #72 on: June 26, 2008, 01:14:50 AM »
Updating this thread with this Pic.
I will start a new thread !
Joe-Dokes
« Reply #73 on: June 26, 2008, 09:01:16 PM »
Very Very Nice.
Joe Dokes
dd69a
« Reply #74 on: June 26, 2008, 11:18:15 PM »
absolutly awesome
69-DART
« Reply #75 on: September 23, 2008, 11:54:55 PM »
HAVE TO HAVE THIS SIZE TIRE AND WHEEL
IS THEIR MORE SPACE IN THE REAR OF THESE THINGS THAN THE DART?
Datsbad
« Reply #76 on: September 24, 2008, 12:10:45 AM »
I dont beleive so , we moved the tubs into the frame rail.
Here is a small update on another website. http://www.pro-touring.com/forum/showthread.php?p=438927#post438927
69-DART
« Reply #77 on: September 24, 2008, 10:43:26 AM »
AWSOME...DUDE IF YOU DONT MIND COULD YOU SHARE THE DEMETIONS OF THIS SET UP IE: TIRE AND WHEEL SIZE/BACK SPACING AND AXLE WIDTH /WMS
AFTER SEEING THIS SET-UP I DON'T THINK I'LL EVER BEEN SATISFIED WITH ANYTHING LESS...NICE WORK
Datsbad
« Reply #78 on: September 24, 2008, 10:52:47 AM »
Thanks for the compliments.
Rear wheels are 18x12 with a 5.5 bs, rear end length is 51" that is axle end to axle end. housing flange to flange is 46" , housing flange end to axle end is 2.5 , I have pinion center meassurements if you need them also.
I am running a 18x8.5 front wheel with a 245/35 tire , rears are 335/30
Hope this helps
« Reply #79 on: September 24, 2008, 11:45:47 AM »
Demons / Dusters have larger rear tubs...before and after mini tubbing to the frame rail.
Datsbad
« Reply #80 on: September 24, 2008, 11:47:44 AM »
There you go ....We have a winner.
69-DART
« Reply #81 on: September 24, 2008, 12:53:18 PM »
DAMN...BY HOW MUCH?
69-DART
« Reply #82 on: September 28, 2008, 11:36:15 PM »
ANYONE?
69-DART
« Reply #83 on: October 06, 2008, 12:54:49 PM »
BUMP....
blackbetty
RoadKiller
« Reply #84 on: October 06, 2008, 04:58:44 PM »
I had 17x10.5 on the back of my dart before my project went crazy I think the tires were 315/35/17s.
71 Dart,BB,t56,tube chassis,6in engine setback,Modified C4 corvette front suspension,custom 3link rear. Shooting for 200mph at the Maxton mile.
Make the asphalt bleed!
Pages: 1 2 [3]  All Go Up Print
