November 23, 2008, 12:25:32 PM
| | |-+  steering question
Author Topic: steering question  (Read 180 times)
prodart340
steering question
« on: February 03, 2008, 05:45:42 PM »
 I would like to put manual steering on my '74 swinger. I have the entire front suspension from a retired drag car that was a '69, that is manual, along with the steering column. My question is this, if I change idler arm, pitman arm, and center link {dropped center}, along with going to the C body inner and outer tie rods that I was planning on doing anyway, will this all come together and be pretty much a bolt in or is there going to be some caveman engineering that I will encounter? Sorry so long winded but want to make my intentions clear. motorinstall
70 Dustpan
Sacramento CA.
Re: steering question
« Reply #1 on: February 03, 2008, 05:51:42 PM »
No if you got all the aparts it will all just bolt in.
Hey, I'm a God again!
evstraus
« Reply #2 on: February 03, 2008, 06:27:10 PM »
Steering column is different. 70 and up the ignition key is in the column, 69 and down in the dash. I think the mounting under the dash can be swithed over though. Eric  4 speed
70 Dustpan
Sacramento CA.
« Reply #3 on: February 04, 2008, 12:30:34 AM »
Yes this is true, but you can swap just the center shaft in the columns and keep the later column in the car.
prodart340
« Reply #4 on: February 04, 2008, 06:18:24 PM »
  sorry, new to this suspension/steering stuff,,,,how might one go about changing this "center shaft" Popcorn
