October 15, 2008, 06:32:38 PM
Pages: 1 2 3 [4] 5 Go Down Print
Author Topic: A-body Heddman headers install w/ B engine.  (Read 4374 times)
Re: A-body Heddman headers install w/ B engine.
« Reply #90 on: March 17, 2008, 11:30:06 AM »
Um....What collumn? (look at the pics again)  Wink
mopar_eric
BBD BABY
« Reply #91 on: March 17, 2008, 02:07:58 PM »
Thats what I get for opening my mouth first thing in the AM lol....explode
Looks good dude!
« Reply #92 on: March 17, 2008, 02:14:08 PM »
I was totally amazed athow much splatter and slag there was from the welding on the K-member, I kept trying to scrub off the stuff, then I realized what it was. The welds look real strong, and there was no rust anywhere except for the surface rust. The fenders look rust, but it really is just light surface rust with hardly and pitting.As soon as I get the engine in, I will get the headers fit in, then yank it all and start sanding. It should only take a day for that.
Caledonia, ON Canada
« Reply #93 on: March 17, 2008, 02:25:48 PM »
Things will be a lot easier if you pull out the torsion bars, install the headers, and then try and slide the torsion bars back in to check where you need to ding the drivers side tubes.  You are lucky, with the late model steering linkage you shouldn't have any clearance issues there.
damopars
VA
« Reply #94 on: March 17, 2008, 02:31:12 PM »
Looks good, hope you get those headers in with out
I had no luck with them on my car. Maybe if you go in from under the car.
Dave
« Reply #95 on: March 17, 2008, 02:53:17 PM »
I think the reason they do seem to have the clearance is that the car has a 73+ K frame. I have heard about fit issues and that these tend to be in early K-frame cars, and the late steering linkage seems to clear everything with an abundant amount of room. As a matter of fact, I think there is enough room under there for a huge sump. I will know for sure in a few days how they fit. Honestly, it is so easy to pull and engine, I don't know why people try to install headers with the engine it. It took 2 people about 30 min to pull the engine and trans as one unit.
kzinge1
'70 Dart 383
« Reply #96 on: March 17, 2008, 04:57:18 PM »
Good luck with the Heddman's. I couldn't make them work. Too much dimpling (or should I saw crushing) of the pipes around the steering box and the column. I would have ended up with two pipes that were less than 1 1/2". Passenger side was a great fit though.
« Reply #97 on: March 17, 2008, 04:57:40 PM »
Looking good Fly ... I'm always amazed at how many runs there are in a factory engine bay ... keep the pics flowing
« Reply #98 on: March 17, 2008, 06:23:14 PM »
OMG yes! Drip and runs galore! I scraped off all the seam sealer that was dripped all over, it could fill up a quart cup. There is one run that if you measured the edge along the drip, it would be 2 feet long!
Overall, there are no rust holes anywhere, there are only a few extra screw holes (maybe 6) and one dent in the pass inner that looks like someone threw a 1/2 ratchet at the car (I could understand  Grin ). I am  not going to go nuts filling holes and patching screw holes, I will probably weld up 6 holes, knock out the small dent, and thats it. Just primer and paint.
68snewpy
« Reply #99 on: March 18, 2008, 11:46:54 AM »
If it's not too much of a PITA could you try mocking up the power steering box when you test fit the engine.  I need to order some headers and I'm caught between the Hedmans and Schumachers.
« Reply #100 on: March 18, 2008, 11:52:00 AM »
I am curious myself, so I will try it. One condition, you need to come over and clean all the grime off my PS box, I just cleaned the K-member.  Wink
« Reply #101 on: March 18, 2008, 01:58:11 PM »
Not wanting to burst your bubble, but the headers snake around the standard steering box like they were made for it, but with only fractions of an inch of clearance.  I don't think there is a hope with the power steering box.
CARR68
« Reply #102 on: March 18, 2008, 07:07:34 PM »
Great work with your project and keeping other members totally updated. I am also at the point where will  it be Schumakers, TTI, or give the Hedman's  a try. thank you
68snewpy
« Reply #103 on: March 18, 2008, 10:24:30 PM »
No problem but I'll be awhile getting there from Canada. 4 speed
From this pic, it kinda looks like the extra length of the PS box will be OK.  In fact the coupler might be far enough up the shaft that clearance may be improved at that point.
Just hanging onto my false optimism. Grin
nightrider
Duster Buster
« Reply #104 on: March 19, 2008, 02:06:20 PM »
Sorry I haven't gotten the pics... damn charger is lost for my camera... BAH!
I am using your picture to highlight the dings... the red are must dings for the steering box(manual) and coupler, the bottom one is for the drivers side torsion bar.
Then blue circles are where you might possible have to ding to clear the cotter pin for the centerlink and the lil bung on the ministarter. The passenger side should not require any.... maybe a lil ding for the centerlink there as well...
nightrider
Duster Buster
« Reply #105 on: March 19, 2008, 02:11:53 PM »
Oh yeah, the steering box actually clears without dings on the #3 cylinder pipe, but it still has to be dinged to compensate for engine torsion when throttling... unless you are using solid mounts... i gave mine 1/4" clearances in the red spots just to make sure they wont rattle when i giv'er the juice! Those red circles are about the size of the 'dings' you'll need to make too....
« Reply #106 on: March 19, 2008, 08:39:51 PM »
Whats the ding on the floor for? I was hoping I could leave the garage floor unmodified.
bigtimeauto
Plymouth meeting, PA
« Reply #107 on: March 19, 2008, 09:18:44 PM »
Good eye's! I'll bet that's where you put the wheel on the engine stand so it doesn't move. LOL
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
nightrider
Duster Buster
« Reply #108 on: March 20, 2008, 01:20:47 PM »
Thats so my beer won't tip over LOL  moon
« Reply #109 on: March 24, 2008, 09:29:43 AM »
What I did Easter Sunday!
Sorta reminds you of Superman with these colors. The first step was just trying to get this thing in all by myself. It was a handful.
First test fitting of the headers on the drivers side, I will have to make a dent for the torsion bar and it looks like the starter to clear. I used a yellow metal marking crayon to mark the headers.
This tube cleared the firewall with plenty of room.
I made the first clearance for the torsion bar, not enough, gotta do it some more.
I made a dent to clear the starter, but after clearancing the torsion bar, the header shifter position a little and this one ended up not being needed, guess it will keep the starter a little cooler.
Need to clearance it a little more, a piece of paper gets hung up in here.
The firewall clearance did not change
Passenger side cleared the torsion bar fine, I might put a light ding in here to get a little extra clearance.
Good clearance to the right fender, no problems at all.
This one is a little bit more of an issue, The idler arm hits on both tubes, I am going to raise the engine slightly on this side and ding both tubes.
Another view under the pass side header, good clearance to the fender. The number 6 tube hits the back endge of the block and the trans pan rail, I need to clearance both those areas so I can be sure the header is in the right place and I dont have any header leaks.
Another thing I checked, the brake booster clears everything easily, even the valve cover with the clain under it. I will stay with power brakes now.
I still need the Manual steering box and I need to install the collumn to check the rest of the clearances. I am considering cutting the #3 tube and rewelding it for torsion bar clearance. Can you mig weld tubes or do you have to tig weld them?
nightrider
Duster Buster
« Reply #110 on: March 24, 2008, 09:44:30 AM »
Great job! Pretty much where I said the dings need to be made... although the only difference is that you are using an old style starter instead of a mini-starter...
BTW you never took a shot of where you had to ding the floor? :p  lol bash
« Reply #111 on: March 24, 2008, 11:02:27 AM »
I tried to do it with my head, but the floor won.
kzinge1
'70 Dart 383
« Reply #112 on: March 24, 2008, 03:31:52 PM »
Make sure you slide that steering column in to clearance the pipes around it. That's where I had the most trouble. Looks good so far though.
Good Luck.
mopar_eric
BBD BABY
« Reply #113 on: March 24, 2008, 03:36:51 PM »
Pretty sure mig is the way to go there. If you have a tig it may be better but I would think it'd be alot harder.
Looks like mine.... cept mine are on their second repainting :-) I have a few spots that could use a bit more clearance but hey they're in the car so I'm fine to let them clearance themselves while I  4 speed 4 speed 4 speed
« Reply #114 on: March 24, 2008, 04:00:58 PM »
mig will be fine. some times you can get away with cutting a ring out of a tube and closing it up with a ratchet strap and rewelding it, an alternative to dings.
« Reply #115 on: March 24, 2008, 05:00:00 PM »
Those pictures sealed the deal for me ... Mr Reilly will be getting a call from me once I start on my 68, the alterkation is the only way to go.  Those headers have almost as many clearance issues on that low deck as the 2" TTI's  that I swore I could make fit.  Only I spent the better part of 2 days beating and dinging with the car on a lift ... the TTI's won that battle ... just ask B569RR he has what is left of the headers ...  motorinstall
« Reply #116 on: March 24, 2008, 06:13:56 PM »
With the alterkation, it would be an easy fit. I was actually thinking that even with the stock k-frame a coilover conversion would make this an easy fit.
bigtimeauto
« Reply #117 on: March 24, 2008, 09:13:42 PM »
With the alterkation you can even use a reg deck block and indy 440-1 heads with the TTI's and have tons of room.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
nightrider
Duster Buster
« Reply #118 on: March 25, 2008, 09:27:49 AM »
we all must be getting older and lazier, its not that much work... i'd rather ding headers than scrape undercoat! LOL hammer
68snewpy
« Reply #119 on: March 28, 2008, 06:22:04 PM »
Any more progress?      Popcorn
Pages: 1 2 3 [4] 5 Go Up Print
