Topic: Anyone rebuild a manual steering box? (Read 602 times)
wjaholic
I have a manual steering box for my Duster that I want to rebuild my self. I started looking around for instructions or parts and so far I haven't found too much. About the best that I can find is the kit from Firm Feel. I had heard that you can get a kit from the local autoparts stores but so far I havn't had any luck finding it. Any help is greatly appreciated!
mark8denny
I had mine apart when I first got my car at age 16 , I pulled the steering box apart and all I remember was the ballbearings fell out all over !! Why do you want to rebuild it ? They are adjustable to tighten them up , loosen the lock nut and screw inward on the adjuster with a screwdriver. I caution you to adjust it lightly because it is hard to tell , you don't want to crank it in hard. As far as what else I have read... some are full of grease, some have gearlube in them. Mine is full of grease and gearlube. My advice to you is thick oil and an adjustment.
Rides : 1969 Barracuda hardtop 1967 Sunbeam Alpine 1994 Lincoln Mark 8 , 355 RWHP 2003 Ford F 150 supercrew
wjaholic
I bought it at a swap meet, it is used and has been adjusted all the way in. I pulled the "cap" off to see. It is full of grease. I want to rebuild it before I get my engine back in my car.
mark8denny
maybe use the firm feel kit to make a better ratio  maybe they have all the seals you would need too ? mine is adjusted inward ( a little less than the full adj nut ), but works fine. Good Luck !
jet-taz
they should be filled with grease my nos box was. i got this from a manual hope it helps.
If it doesn't leak, you probably don't need to rebuild it, but just adjust it properly. If you must rebuild, you probably just need the two seals ($50 from Firm Feel - robbery if you ask me) and Mancini sells the 20:1 worm gear. I called Firm Feel and they said to fill it with gear oil. I did. It doesn't leak.
wild383
When I rebuilt mine I used the Firm Feel parts and packed it near full with quality moly grease. The Firm Feel kit was on the pricey side but I just wanted to get it done.  One less thing to worry about. Willie
robx4406
Holy shiznit, the worm gear at mancini's is $235.
I rebuilt one from my old 67 cougar. somewhat similar recirculating ball blah blah blah. it wouldnt adjust for squat so I took it apart. one ball bearing had sheared in half. got a replacement ball bearing from the local mustang guy for nada. heavy grease to hold everything in place and some patience.
wasnt what I could call difficult as I recall.
mine needs to be rebuilt too and i just dont know what i want to do. they are pricey to rebuild, even worse to buy a rebuilt one, then there is the flaming river piece...
70dust
Steer-n-gear has cheaper prices than firm feel and also specialize in mopars.They are located in columbus ohio.They also race mopars!
Guys - they are NOT hard to rebuild at ALL! The seals are spendy, and IF you need a bearing that's more, but I'd bet most of them don't need replacements. I had one with a broken cage, but had an extra box for parts so it donated a bearing. That's really all the moving parts in there. I wouldn't pay someone to do it.
dodgeboy
Online
Mine was leaking, bought a seal kit from advance auto parts for less than $15, installed it and good to go. Roger
DOH
wjaholic
You wouldn't happen to know any part number for that kit, or what car you would have them look up. I have an advance auto parts right up the road, but I can only find power steering parts on there website. I pulled my box apart yesterday and cleaned it and sand blasted it, it looks like I will only need 2 bearings and new seals.
Spook50
Yeah, I work on these
I need to do this as well, once I can get my hands on a box (or two so I can use one as a parts donor). I've got a brand new 20:1 gearset that I got from a dude for dirt cheap since he kept his power steering setup, so once I can get a manual box and rebuild it I can convert from power to manual. Maybe it's just because I don't have one in hand, but I'm lost as to what exactly needs to be done when rebuilding a manual box. I would assume there are torque requirements for the bolts holding it all together and a certain starting point for the adjuster screw when the box is freshly rebuilt. That oughta help me fit the 383 in when the time comes
BOOM shalock-lock boom...
wild383
When I rebuilt mine, I'd never been inside one before. With the Firm Feel kit and a few hand tools, I think I did a darn good job. Like Ciscodog said, it's not hard at all. Willie
