December 03, 2008, 04:55:51 PM
| | |-+  Under hood detail
Author Topic: Under hood detail  (Read 274 times)
JL67gt
Under hood detail
« on: February 06, 2008, 11:56:04 PM »
I have done alot of cars in the past useing blaster its messy.I want to know if thers a better way to clean and paint
hemi_jay
Mopar FTW!
Re: Under hood detail
« Reply #1 on: February 07, 2008, 07:41:47 AM »
I have noticed that blasting the hood (and trunk) makes it very difficult to completely remove the grit for the inner structure. I spent many hours doing that and I would in the future use chemicals rather. some paint stripper to begin with, wash it off with laquer thinners then get some high quality iron/sheetmetal cleaner. Its a mild corrosive that attacks rust and all the nastiness paint striper can't take off. clean it off with laquer thinners again. dont ever use pool/hydrochloric acid... I figured that out the hard way. leaves residue which is very hard to remove and flash rusting is almost instantly after you remove the acid. Hope that helps! Oh yeah after I did my hood and trunk by sandblasting, i did the above method with the doors and other sheetmetal, it works great.
Le Mans blue Victor headed 496 '68 Barracuda
JL67gt
« Reply #2 on: February 07, 2008, 10:15:44 PM »
Thanks am going to try the stripper
« Reply #3 on: February 07, 2008, 10:56:22 PM »
  I used  the paint stripper and a couple wire brushes. One big one, like the one that is supposed to be used for cleaning the paint chips off your wood work on the house, and a smaller toothbuush size, for getting into the smaller areas. This made using the "aircraft" paint remover much easier and more effective. Just make sure you use glasses, long sleeved shirts and gloves. OH, and have plenty of water on standby in case it does get on you. Viscious stuff!
75Dart440
« Reply #4 on: February 08, 2008, 09:43:53 PM »
I used a paint stripping disk on a 4-inch angle grinder, and a dremel tool with flap disks to get into the tight spots and detail areas on the firewall.  Took me about 9 evenings to get it all down to bare steel so I could weld any rust areas up.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
Ft. Worth TX.
« Reply #5 on: February 08, 2008, 10:21:30 PM »
Looks great.
Cary Snyder
5.7L Hemi Cuda
75Dart440
« Reply #6 on: February 08, 2008, 10:35:31 PM »
Thanks!
As you can see I am in the process of changing from Blue to Yellow   Grin
hemi_jay
Mopar FTW!
« Reply #7 on: February 09, 2008, 12:44:39 PM »
The yellow is a nice color!
