December 03, 2008, 02:47:55 AM
| | |-+  Stealth pinch wall thickness?
Pages: 1 [2] 3  All Go Down Print
Author Topic: Stealth pinch wall thickness?  (Read 1789 times)
Draginmopars
Re: Stealth pinch wall thickness?
« Reply #30 on: February 14, 2008, 04:04:36 PM »
Nice work Draginmopars can't wait to see numbers thanks for all the pics and documentation.
 Thank You
"Stealth Mode"   83 Shelby Rampage     Ha-Ha Racin   Havin Fun101
R5-P7 project
« Reply #31 on: February 14, 2008, 08:37:58 PM »
Hey Dragginmopars, you're quite an inspiration! I don't have the nuggets to do my
own porting. My porter said he would go as high as he has to on the intake ports;
I'll add a little weld across the top if I have to. The pushrod pinch is the real problem
area with BB mopar heads. I'll post some pictures when he's finished with them. I
left a Maxwedge head with him for reference. He said he could do better than that!
Draginmopars
« Reply #32 on: February 14, 2008, 09:38:59 PM »
 Thank You, Sir You have an interesting project there
 The max Window is good at 3.650" and 1.380"+
I'm only going to be  2.475" and 1.250"+ or - .075" demon
I'm at the cross road
spool up to the line/Turbo, or
blow it off the line/ Pro Charger
 !nanr Dunno    4 speed drag tree 4 speed
Draginmopars
« Reply #33 on: February 14, 2008, 09:43:07 PM »
Got back to the Intake side today
1 and 1/2 opened up Wink
gotta chisel out some more,
at the roof Grin
ab7fh
« Reply #34 on: February 15, 2008, 10:57:17 AM »
Is the valve guide removed? Or ground down? If it's ground down, I see that you left it intact on the intake side. Why is that? Just haven't got there, or something else?
Draginmopars
« Reply #35 on: February 15, 2008, 11:17:24 AM »
Thanks for looking Grin
exhaust guide is ground down/
profile to the bowl curve
Intake / haven't got that far
removing the pinch/ opening the throat
is trickey
I do the guide work almost last
after the bowl work, then
measure/polish
THEN
4 speed
mopar_eric
BBD BABY
« Reply #36 on: February 15, 2008, 02:43:26 PM »
Very cool! Keep it comin!
Popcorn Popcorn Popcorn Popcorn Popcorn
Draginmopars
« Reply #37 on: February 15, 2008, 09:04:13 PM »
NO more Work
to the Heads   Huh
 for a few days Whew
My "Jaws" machine is broken
Gotta get it fixed first
 It pays the Bills, and to play !nanr
Draginmopars
« Reply #38 on: February 16, 2008, 09:03:20 PM »
waitin on seals and packing
at work
Got my hands, full of intake port.
wiggle room !nanr
gonna take the heads
across the street/machine shop
to open up the seat throat, to eliminate the step.
(seat insert to bowl area.)< +.010" dia.
Then
polish intakes.
One head Done Whew Whew Whew
Next... motorinstall Cheers
Draginmopars
« Reply #39 on: February 17, 2008, 07:27:46 PM »
2 weeks to lose
1/4 lb !nanr Cheers
R5-P7 project
« Reply #40 on: February 17, 2008, 09:31:51 PM »
Looking Good,  Draginmopars
                                       It is very impressive what you have accomplished in such
a short time. What valves are you going to use? Thanks for keeping us posted.
        Cheers,  Budd
Draginmopars
« Reply #41 on: February 17, 2008, 11:56:28 PM »
        Cheers,  Budd
 Dunno 1 down, 1 to go
will be using the SS valves
that came with head
there IS Still
 alot that can be done
would love to cut !nanr
this one in half, to inspect
if I could,
 find a replacement Wink
 even using a Bore scope, and lights/small mirrors
 looking in the water side.
 can't see enough Sad
Competition Wedge
« Reply #42 on: February 18, 2008, 12:43:32 PM »
I have a new set with flow numbers for sale if anyone is interested.
Is there a place to post FOR SALE ads on bbd sign?
Thank you.
Todd
Competition Wedge Engines
Syracuse, NY
Home of past Summit National Champion Mike Larose
Draginmopars
« Reply #43 on: February 18, 2008, 10:49:32 PM »
Thank you.
Todd
 Maybe lol LOL
how about some info
about those heads !nanr
 port window size
pinch area size
throat size/before bowl
 port volume
 FLOW #'s/ price   Popcorn
dusterdood
« Reply #44 on: February 19, 2008, 07:43:20 AM »
He (Todd) was asking $899. Flyboy has started a site to post for sale items. You can see the thread stickied here at the top of the wanted section.
Mike
Rochester, NY 14616
slippery440
« Reply #45 on: February 19, 2008, 08:58:29 AM »
Mike I can not even get on the site because I don't post enough. But this has nothing to do with this post.Waiting for my machine shop to get busy on my heads. Sent them this post so they have a referance.Thanks Vic
Draginmopars
« Reply #46 on: February 19, 2008, 08:13:54 PM »
 puttin tha "Shine" 2 them Cheers Cheers
ab7fh
« Reply #47 on: March 06, 2008, 10:38:25 AM »
All done??
512Stroker
« Reply #48 on: March 06, 2008, 06:58:34 PM »
I'm lost... what did you do...  I have never ported/polished heads before. Dunno
There is no replacement for displacement...
Currently 1970 Dart Swinger 318/904 (Work in progress)
Soon to be 383--496/727, 8 3/4
Draginmopars
« Reply #49 on: March 08, 2008, 11:00:36 PM »
All done??
 LOL I'm Never Done Cheers
 my elbow/arm is done porting for now Whew
needs a break, So I have been
checking rod clearances.
Got the Triple springs in today Cheers
 mockin them up and checking clearance.
Crane R-284* .690"
then deck the block. Then,,
shave the heads for, Compression... Then
 4 speed
ab7fh
« Reply #50 on: March 09, 2008, 10:26:34 AM »
Dang, that's a big heap of shavings:D
I can relate with the arm/elbow thing. My wife just massaged my arm last night and I had to ice it down. I've been doing a bunch of grinding with a 4" in some awkward positions. It gets to be brutal after awhile.
Draginmopars
« Reply #51 on: March 10, 2008, 10:15:37 PM »
 I hear ya, even my air powered Spring compressor, acted weak..
 when putting the triple springs on
 to check for coil bind.
almost couldn't compress them
  @145 closed
thecarfarmer
« Reply #52 on: March 13, 2008, 12:01:49 AM »
Progress???  Inquiring minds want to know.
Also, how much $$$ is involved in getting the outside of the pushrod pinch area welded up?
The reason I ask, is that I just bought rockers for my stroker project:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=330217217941&ssPageName=STRK:MEWN:IT&ih=014
-bill
Check out my STAINLESS no-drill tach brackets,
Skid plates, and A-body spring relocation kits!
Draginmopars
« Reply #53 on: March 13, 2008, 12:40:53 AM »
get the block tomorrow (decked)
then check
Piston to valve clearance again
maybe mill the heads some more Evil
Can't say about Welding, Haven't welded, on mine.
thecarfarmer
« Reply #54 on: March 13, 2008, 04:53:19 AM »
Oops... I guess I gots to pay more attention to the name on the left side...  that's R5-P7 project's post.
So, is there a target chamber size after milling, or just as small as can be done w/ mechanical considerations (valve clearance, etc)?
-bill
375InStroke
« Reply #55 on: March 19, 2008, 02:09:07 AM »
Bump
Draginmopars
« Reply #56 on: March 23, 2008, 12:37:31 AM »
Bump
Got the short block together  Cheers
1759g-bob weight
Cut .300" off the counter weights- to balance
Dang, Spiral locks, glad that's over with.
 next to check valve clearance to
 mill head. .075" + or - for compression
 Popcorn
R5-P7 project
« Reply #57 on: March 23, 2008, 01:02:37 PM »
Looking good, how about some pics of those heads, if you're finished with them.  Thanks for the update.
Draginmopars
« Reply #58 on: March 24, 2008, 10:04:23 PM »
Hello Budd,
How are You doing
on your project?Huh?
 My Heads are at the machine shop
being milled !nanr
jyrki
« Reply #59 on: March 25, 2008, 03:55:42 AM »
 Popcorn
Wait until you have to REMOVE the spiro locks!  Grin
What kind of valve spring pressures do you have? Just wondering how long it will take until those crane rockers come through the valve covers.  Grin
Pages: 1 [2] 3  All Go Up
