Topic: oil pan gasket (Read 264 times)
moparn1
Full Monty Racing
it can be done, it's kind of a pain to get to all of the bolts and you have to remove the centerlink but I have done it successfully.
bow chicka bow wow
I think it would be easier just to unbolt the mounts and pull the engine up 2 or 3 inches. I think it would be easier than doing it in the car. Plus the chances of getting the new gasket in in one piece are slim, possible, but difficult.
Cheap trick department - use the twist ties, off the bread or sandwich baggies, to hold the gasket in place through the bolt holes, as you go along. Remember, there is a pick -up going down the middle of everyting you'll have to navigate around too. I don't know if you can wrestle the gasket around the outside of the pan, avoiding the pick-up confrontation, and not tearing the gasket, or not. It is not mission: impossible, but it is mission: annoying. Be prepared to call it a few names and question its parentage.
jackie
you will have to take off the windage tray off also, the gaskets are above, and below it.
 If you're doing one only, how do you know which one is leaking? Be prepared to do both, just in case you tear one.
I've done cam swaps without touching the oil pan. I've just unbolted the timing cover and removed it while leaving the pan gaskets intact. Only thing is, I built the engine sorta knowing I was going to do that. I guess an older engine or one built with sealant may rip the gaskets.
mopar_eric
BBD BABY
I'd pull that sucker out. you're only adding headers, bellhousing, 2 starter bolts, 4 converter bolts and a few odds and ends to your total time wrenching.
Plus you can do a way cleaner job, and if there's any doubt about your internals now is the time to check it out.
Pro Street dart
I put the Felpro-Performance 1834 oil pan gasket on dry. So far not a drop of oil from it.
