December 03, 2008, 02:40:56 AM
| | |-+  Torsion bar question
Author Topic: Torsion bar question  (Read 461 times)
79ramcharger
« on: February 12, 2008, 12:08:36 AM »
I know that the torsion bars are right and left. I pulled a pair of factory v8 bars out of a car and did not mark them. Is there some marking on the bars I should be looking for? Or should I not worry about it?
Thanks,
Steve
fourspeed
Wisconsin
Re: Torsion bar question
« Reply #1 on: February 12, 2008, 12:13:11 AM »
Yes, you DO need to worry about it! On the end of the rear hex, they will be stamped with numbers. Mine had an R on the right one if I remember right. If not, post the numbers that are stamped on the bars.
79ramcharger
« Reply #2 on: February 12, 2008, 12:15:30 AM »
Thank you, now I know where to look.
Steve
DartKnight
« Reply #3 on: February 12, 2008, 01:02:41 AM »
They also had stripes painted on them (if they're stock) to denote which side they go on, one had one stripe and the other had two. I can't remember which stripes identify which side, though.....so I guess that didn't help much.  Grin
Jason
75Dart440
« Reply #4 on: February 12, 2008, 08:23:36 PM »
Left side had 2 paint blotches and right side had 1
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
75Dart440
« Reply #5 on: February 12, 2008, 08:25:18 PM »
Also, part numbers ending in odd numbers are usually drivers side and even ones are passenger side.
oldkimmer
« Reply #6 on: February 19, 2008, 07:01:35 AM »
.............And the paint marks go to the rear..........kim..........
69DartW250
« Reply #7 on: February 19, 2008, 07:12:53 AM »
Just to add to this discussion....
There is a line stamped on each end of the bars. How should the bars be installed in relation to these lines.....or does it not matter?
Kim, I always thought the paint marks went towards the front. Glad I read this thread, thanks.
George
1990 Dodge W250 4X4, 4 speed
1969 Dodge Dart Swinger 340, auto 727
75Dart440
« Reply #8 on: March 01, 2008, 03:22:30 PM »
George
The line doesn't make any difference as far as how it is aligned in the socket during installation.  The bars have a pre-engineered amount of twist in them from front to rear.  This twist will be the same no matter how you orient the lines on the ends of the bars.  I just make sure that I have the appropriate bar on the correct side and front of the bar to the front of the car!
69DartW250
« Reply #9 on: March 01, 2008, 05:11:03 PM »
Thank You 75Dart440-
Again, the paint splotches from the factory go towards the BACK of the car, correct?
TWO paint splotches on the drivers side, ONE on the pass side.
George
75Dart440
« Reply #10 on: March 01, 2008, 06:51:57 PM »
You got it!  The rear of the bars will have the the last 3 digits of the part number stamped on them as well.
75Dart440
« Reply #11 on: March 01, 2008, 08:40:58 PM »
/6 bars are commonly used for racing A-bodies with big blocks in them.  The bars allow the front of the car to react faster upon launching the car.  I personally wouldn't run them on the street as they are oil pan killers and they could break on you with the constant beating they will take.
