Topic: Torque specs (Read 175 times)
hemi_jay
What are the torque specs for the: k-member to frame, UCAs and leaf springs? Should I use red/blue loctite on any? Or just some anti-sieze? Also, the UCAs, iv'e noticed that if they are turned down to much, they cant move any more. What is the correct way to set them up? Thanks for any advice
 Le Mans blue Victor headed 496 '68 Barracuda
I don't know any specs offhand, but I would use blue Loctite on the K frame bolts. Loctite prevents the threads from rusting also since it blocks air from getting at the steel.
The leaf spring bushing bolts should not be tightened until the car is weighted properly, otherwise, they bind with the car jacked up.
smallbigblock
 I need the same info
I should have left it alone
jbarker
Leaf spring to axle U bolts are torqued to 45 ft-lbs. Don't know the other specs off hand. -Jay
67 dartgts
Lower control arms Front Strut Nut = 40 ft pounds Rear Strut Nut = 110 ft. pounds
Pivot shaft nut = 180 ft. pounds Shock absorber = 55 ft pounds Upper Control arm = 55 foot pounds on adjusting nut Lower Stud nut = 55 foot pounds
K Member = 150 foot pounds
From 1967 Dodge service manual. You might consider buying a manuaL.
Maynard
hemi_jay
Thank you so much, yeah I should buy a manual, where can I find one?
67 dartgts
Hello:
E-bay
Maynard
MVRCorp
67 dartgts
Hello: Yep thats the critter.
Maynard
