Topic: Rear Disk setup! (Read 1000 times)
ksdartguy
Anyone use this type setup yet for rear disk? I bought the brackets of ebag, lincoln continental rotors,GM calipers and hardware. Looks like it will work pretty well. Ive got about $300 in the whole setup. I wasnt planning an ebrake, although, you can use Caddy eldorado calipers if you want them. Rick
ksdartguy
Sorry, not very good pics.
ksdartguy
heres another
Who makes the brackets, is it Scarebird?
ksdartguy
Bought them from Talzag auctions. Havent seen more since then.
44073dust
^ SHAKE IT !!
Its the scarebird setp, they sell or used to sell under that username on ebay.
daniel_depetro
Your set-up looks great. I used 1994-98 Jeep Grand Cherokee rear disk brake set-up. It's a direct bolt on (need to enlarge the center bore hole a bit with a die-grinder/dremel). I got my entire set-up for $145.00 shipped to my house. I used the original calipers and rotors as the ones that I got from the salvage yard were like new. I didn't install the P-brake system either, but I have it if I ever decide to. This is the same set-up I used: http://home.swbell.net/rriojas3/reardisk.html
68fish
That looks like a nice set up. Did you have to do anything different with the proportioning valve?
I have the same set up for my Dart although I have to have special spacers made because I'm still running the OEM axles. (They were modified by Currie to the 5 - 4 1/2" circle but the center register is still A body small. That's where the spacer is needed to make it B body wheel friendly.) The really COOL part is that it does NOT require "Green" bearings and all parts are available at local parts stores every where. Well thought out if uyou ask me. I can hardly wait to get them put on.
44073dust
^ SHAKE IT !!
ksdartguy
No the inside bracket is 1 piece on mine. I had my axles made with a little smaller center ring for the lincoln rotors. Now they use standard parts store parts, and fit 15" wheels. I've had steel and welds on there.
ksdartguy
I have the stock one for now. Have to see how it stops. DHas anyone else had to change Pvalve to get it to stop better? Rick
Huh - you're right. Maybe they changed their brackets? I looked into it years ago and they looked like the one that is posted above (one piece). Either way it uses the same hardware. Good route to go if you want an e-brake.
BacktoBasics
It definately looks like a scarebird system to me:
ksdartguy
It definately looks like a scarebird system to me:  Yes thats it. Continental rotors and GM calipers and pads, pretty straight forward. Has anyone used theirs? How do they stop? I wondered if I will need the adjustable proportioning valve. Rick
268darts
It looks like the Ford rear disc set up. I tryed to put on of their backing plate over an 8 1/4 housing end at the JY. It went about a 1/4 on to the housing. It wouldn't have taken much for it to go all the way on. Maybe just take the paint off the housing end.  It looked like it might work. http://www.explorer4x4.com/discswap.html
kowski71400
puregts. what system does not require green bearings?
Any of these systems with GM calipers don't need green bearings - the calipers are floating so they align regardless. Kits like the wilwood use rigid-mounted calipers, so they need the fixed position bearings.
IL.DART340- 4SP
heres another
What year is the lincoln rotors off? Is that a black Mustang I see in that photo?
Looks like a nice setup. But personally I would only use it on a street use only car. After working on a gm metric chassis Pro Truck for just one season and going through 3 pairs of calipers on our race truck and seeing probably 15 more pairs go bad on half a dozen other competitiors race trucks i wouldn't use it on my car, my dart will be road course raced once in a while, driven to the track and driven home and I have no interest in replacing and bleeding brakes before I head home. But non-the-less nice setup and good work.
andyf
The GM calipers have really big pistons in them so you have to run super big pistons up front. If you use big pistons in the rear and small pistons up front then the car will spin when you stomp on the brakes. You do NOT want the brake system to be rear biased, it needs to be heavily front biased. (If you don't know how to calculate brake bias is then you shouldn't be Frankensteining your own brake system.)
I have to agree there. When my dart finally gets brakes I'm upgrading to Viper(6 piston calipers) up front and wilwood(4 piston calipers) in the rear
scott
69 Valiant
Your set-up looks great. I used 1994-98 Jeep Grand Cherokee rear disk brake set-up. It's a direct bolt on (need to enlarge the center bore hole a bit with a die-grinder/dremel). I got my entire set-up for $145.00 shipped to my house. I used the original calipers and rotors as the ones that I got from the salvage yard were like new. I didn't install the P-brake system either, but I have it if I ever decide to. This is the same set-up I used: http://home.swbell.net/rriojas3/reardisk.htmlNot too bad .. I may have to check it out a little further at the local bone yard for availability..
moparchop
Some of the multi piston calipers dont work to well when cool.Need to be heated up real good to work efficiantly.Designed for road racing.....
440goldduster
Some but stuff like the Viper calipers are used on the street all the time and the wilwoods are designed for street/race use.
moparchop
Your right,I had to get daughter through collage.Lost some time and technology has passed my by.Old school.But I will catch up soon.
440goldduster
