Topic: Can the shock towers be cut down with AlterKation front end? (Read 711 times)
Billet Badges
I am getting ready to install a 6.1L with the AlterKation front end in my 70 Road Runner. With the AlterKation front end, are the old shock towers needed? If they are not needed anymore, I am looking at cutting them out to clean it up and to give a bit more clearance for the engine. Is this a good or bad idea?
gocirino
I cut mine out of my 68' Dart 6.1 Hemi. Who needs them after you put the Alter K in anyway?
Billet Badges
Do you have any pictures of your engine bay and wheel well after these mods?
Here's a couple pic of mine. Let me know if you want more. Jim
that's some nice work MVR ....
Billet Badges
MVR, Thanks for the pictures. That is just what I was thinking of doing but on a B body. Here is what I was thinking on my towers.  It will give a bit more clearance for the 6.1 or just clean up the engine bay. Who knows, maybe I will need the room for twin turbos!!!  !
Another pic. I drilled 1-1/4" holes at the corners to radius and relief the stress then bent the metal to match the radius.
zpsull01
What exactly do you mean by this? I am also looking into doing this soon.
Billet Badges
What exactly do you mean by this? I am also looking into doing this soon. Instead of having sharp corners, he has drilled large holes and then cut out between the holes. This will leave a nice radius on all the corners which will relieve the stress in the part.
zpsull01
Oh I see what you mean. How hard is it to bend the metal for that? I don't have access to a brake that's why I'm asking. I thought about doing this in two pieces. The horizontal and the vertical piece, then weld the seam but I am afraid it won't look as good.
AlterK and no shock towers here
I used 18ga metal and had them bend the radius I wanted, traced the cut lines with a sharpie and cut it with a jig saw with a fine metal cutting blade.
johnmw
Here's one way to cover those shock holes.
Billet Badges
That is a great idea. Since I make custom billet aluminum emblems, I think that I can do something like that really easy.
Billet, Just for the record, the GenIII Hemi fits into the B and E bodies with plenty of room to spare. If you were to modify the shock towers, it would be for asthetic purposes only, cause you have plenty of room...
Darius
I am also getting real close to installing an Alterktion in my 70 GTX, along with a genIII Hemi. I will be interested to see how your install goes, hope you will be so kind as to post some progress pics. Thanks in advance!
moparchop
I had thought about alterk.,but that is a lot of money.I think I will shop around.But ,to shave 150 lbs. off the front end will really help with the weight of a big block.How about handling,and performance.
440goldduster
You're right but it's more than the weight savings.....R & P steering, way more space for headers and starter, improved suspension geometry for bigger wheels/tires. more brake options, etc.... If you are rebuilding the whole front end of your stock stuff, the AlterK is not that expensive. IMHO
moparchop
Your right,I know I will be upgrading the steering and brakes the whole works.I remember hearing about something eles had to be done .Moving something at an angle for a bodies.cant remember.
440goldduster
bigtimeauto
the only *thing* that has to be done is you need to remove the lower bumpstop bracket. after that its a bolt in. I have under the car to check everything before i powder coat it. If you guys need any pics just yell.
moparchop
Yes,I would like to see some pictures.I think you guys helped me make up my mind.Thanks again
440goldduster
moparchop
tanks,For the pict. I am still trying to get my duster pictures together on this deal.Any way your front end looks great.Next month I am going Alterk.
440goldduster
