November 22, 2008, 07:31:23 PM
| | |-+  Can the shock towers be cut down with AlterKation front end?
Author Topic: Can the shock towers be cut down with AlterKation front end?  (Read 707 times)
Billet Badges
« on: February 17, 2008, 11:20:12 AM »
I am getting ready to install a 6.1L with the AlterKation front end in my 70 Road Runner.  With the AlterKation front end, are the old shock towers needed?  If they are not needed anymore, I am looking at cutting them out to clean it up and to give a bit more clearance for the engine.  Is this a good or bad idea?
gocirino
Re: Can the shock towers be cut down with AlterKation front end?
« Reply #1 on: February 17, 2008, 01:04:40 PM »
I cut mine out of my 68' Dart 6.1 Hemi. Who needs them after you put the Alter K in anyway?
Billet Badges
« Reply #2 on: February 17, 2008, 02:30:31 PM »
Do you have any pictures of your engine bay and wheel well after these mods?
« Reply #3 on: February 17, 2008, 03:51:50 PM »
Here's a couple pic of mine. Let me know if you want more.
Jim
« Reply #4 on: February 17, 2008, 04:27:43 PM »
that's some nice work MVR ....
Billet Badges
« Reply #5 on: February 17, 2008, 11:33:37 PM »
MVR,
Thanks for the pictures.  That is just what I was thinking of doing but on a B body.  Here is what I was thinking on my towers.
It will give a bit more clearance for the 6.1 or just clean up the engine bay.  Who knows, maybe I will need the room for twin turbos!!!  LOL!nanr
« Reply #6 on: February 18, 2008, 12:10:15 AM »
Another pic. I drilled 1-1/4" holes at the corners to radius and relief the stress then bent the metal to match the radius.
zpsull01
« Reply #7 on: February 18, 2008, 12:55:24 AM »
What exactly do you mean by this? I am also looking into doing this soon.
Billet Badges
« Reply #8 on: February 18, 2008, 02:36:26 AM »
Instead of having sharp corners, he has drilled large holes and then cut out between the holes.  This will leave a nice radius on all the corners which will relieve the stress in the part.
zpsull01
« Reply #9 on: February 18, 2008, 01:57:00 PM »
Oh I see what you mean. How hard is it to bend the metal for that? I don't have access to a brake that's why I'm asking. I thought about doing this in two pieces. The horizontal and the vertical piece, then weld the seam but I am afraid it won't look as good.
« Reply #10 on: February 18, 2008, 03:00:49 PM »
AlterK and no shock towers here
« Reply #11 on: February 18, 2008, 04:10:34 PM »
I used 18ga metal and had them bend the radius I wanted, traced the cut lines with a sharpie and cut it with a jig saw with a fine metal cutting blade.
johnmw
« Reply #12 on: February 22, 2008, 01:29:13 AM »
Here's one way to cover those shock holes.
Billet Badges
« Reply #13 on: February 23, 2008, 10:49:27 PM »
That is a great idea.  Since I make custom billet aluminum emblems, I think that I can do something like that really easy.  !nanr
plotners@msn.com
« Reply #14 on: February 24, 2008, 01:05:19 AM »
Billet,
Just for the record, the GenIII Hemi fits into the B and E bodies with plenty of room to spare.   If you were to modify the shock towers, it would be for asthetic purposes only, cause you have plenty of room...
My Mopars:
'69 Cuda SRT8 6.1 Hemi
'05 Jeep Grand Chickeree 4.7
"3 Hemis, no waiting!"
Darius
« Reply #15 on: February 24, 2008, 10:24:21 PM »
I am also getting real close to installing an Alterktion in my 70 GTX, along with a genIII Hemi. I will be interested to see how your install goes, hope you will be so kind as to post some progress pics.
Thanks in advance!
moparchop
porkchop
« Reply #16 on: February 28, 2008, 08:53:27 PM »
I had thought about alterk.,but that is a lot of money.I think I will shop around.But ,to shave 150 lbs. off the front end will really help with the weight of a big block.How about handling,and performance.
440goldduster
« Reply #17 on: February 28, 2008, 09:18:16 PM »
You're right but it's more than the weight savings.....R & P steering, way more space for headers and starter, improved suspension geometry for bigger wheels/tires.  more brake options, etc....  If you are rebuilding the whole front end of your stock stuff, the AlterK is not that expensive.  IMHO
moparchop
porkchop
« Reply #18 on: February 28, 2008, 09:39:39 PM »
Your right,I know I will be upgrading the steering and brakes the whole works.I remember hearing about something eles had to be done .Moving something at an angle for a bodies.cant remember.
440goldduster
bigtimeauto
Plymouth meeting, PA
« Reply #19 on: February 28, 2008, 10:50:49 PM »
the only *thing* that has to be done is you need to remove the lower bumpstop bracket. after that its a bolt in. I have under the car to check everything before i powder coat it. If you guys need any pics just yell.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
moparchop
porkchop
« Reply #20 on: February 29, 2008, 01:07:23 AM »
Yes,I would like to see some pictures.I think you guys helped me make up my mind.Thanks again
440goldduster
moparchop
porkchop
« Reply #21 on: February 29, 2008, 03:25:06 PM »
440goldduster
bigtimeauto
« Reply #22 on: February 29, 2008, 06:23:18 PM »
Here is mocked up, I will post some tomorrow when i cut the stock shock towers off.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
moparchop
porkchop
« Reply #23 on: March 01, 2008, 01:39:40 AM »
tanks,For the pict. I am still trying to get my duster pictures together on this deal.Any way your front end looks great.Next month I am going Alterk.
440goldduster
