November 22, 2008, 07:33:36 PM
| | |-+  What gauge metal for minitubbing?
Author Topic: What gauge metal for minitubbing?  (Read 280 times)
codfish
« on: February 18, 2008, 10:59:29 PM »
In the process of mini tubbing the Dart, and was wondering what gauge metal should I buy to fill in the strip?
thanks
codfish
DRIVE A HYRID.  I NEED YOUR GAS!!!
mopowers
Re: What gauge metal for minitubbing?
« Reply #1 on: February 18, 2008, 11:05:17 PM »
I used 20 because I had some already.  I'd say either 18 or 20 gauge.
2006 Dakota
robx4406
« Reply #2 on: February 19, 2008, 02:15:27 AM »
Cod   I used the skins off a door I had that had burned up.  Made a template of the required section(s) and cut it from the door.
Anything from 18-22 gauge would work.  If you have a torch, anneal it, to make it more pliable and easier to work with.
codfish
« Reply #3 on: February 21, 2008, 10:54:10 AM »
Thanks for the replies guys.
By annealing it, you mean basically heat it up a bit to make it easier to form?  Excuse my ignorance!!
codfish
robx4406
« Reply #4 on: February 21, 2008, 01:05:40 PM »
codfish
Yes, heating it up will change the metals memory and make it easier to form.
I had a pair of doors off a scamp that got BBQ'd.  The panels were much easier to form than the non annealed sheet I had laying around.
Don't know if you've seen this, but, maybe it will help a bit.
http://smg.photobucket.com/albums/v655/crackedback/Mini%20Tub/?action=view&current=edaea261.pbw
codfish
« Reply #5 on: February 22, 2008, 09:49:26 AM »
Thanks Rob.
Yeah I've seen that video before.  It's actually a good tutorial for anyone about to attempt this.
I've finally got one side cut out.  Just trimming it up right now and getting it ready to reinstall.
The only advice I can offer at this point, is if you are using a sawzall for any of the cutting, do yourself a huge favor and get GOOD blades.  I started out using some cheap ones I had in the garage, and I swear I broke 7 blades within 3 minutes of cutting.  I then went and bought some good blades, and I am still on the first one.  Makes life easier.
Oh well.  Back to the garage.  Should take the camera too I guess.
later
gary
