September 07, 2008, 01:57:20 AM
| | |-+  motor plate question
Author Topic: motor plate question  (Read 619 times)
440turner
« on: February 20, 2008, 07:01:57 PM »
  Has anyone used the "new"  fancy designed motor plate that Mancini racing is selling. I was thinking about buying one but not sure. Is there enough material at the area where the plate contacts the frame for me to put large diameter holes for the rubber strut rod bushing style mounting as described in the tech. section? I would appreciate pics if available, especially if they show alternator mounting with this new plate. The car in question is my 67 Barracuda w/440 and the plate is the one thats $175 at Mancini. Thanks in advance
bigtimeauto
Plymouth meeting, PA
Re: motor plate question
« Reply #1 on: February 20, 2008, 07:08:16 PM »
It fits real nice get it. If you want a pic of it in the frame let me know i have one here i can take a picture of.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
bigtimeauto
« Reply #2 on: February 20, 2008, 07:22:58 PM »
here you go, I think *andyf* here actually makes them:
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
440turner
« Reply #3 on: February 20, 2008, 07:23:14 PM »
 If you could post the pic I would appreciate it. I wonder if I could go back to the factory brackets for the alternator, it looks like the top bolt hole into the head clears the plate?
bigtimeauto
« Reply #4 on: February 20, 2008, 07:30:13 PM »
pics are up, you will need to fab a new mmounting system for the alt.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
440turner
« Reply #5 on: February 20, 2008, 07:55:56 PM »
 That really looks good, I can see now that I will not be able to use the factory alt. mounting. I cant use the low mount alt. kit because I still have a mech fuel pump, any ideas?
Midnight Special
GO HARD or GO HOME
midnightsplracin
« Reply #6 on: February 20, 2008, 09:15:21 PM »
Contact Greg w MagnumHP and buy the Moroso big pulley.  You then can mount a low alt kit.
Wichita Kansas Area
NHRA/SFI Tech Inspector
NHRA Division V
« Reply #7 on: February 20, 2008, 09:41:02 PM »
This will show you how the plate fits on the front of the motor.
ari440
« Reply #8 on: February 21, 2008, 07:42:40 PM »
bigtimeauto
« Reply #9 on: February 23, 2008, 05:11:32 PM »
Here is a pic of the engine mocked up in the car with the plate:
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
andyf
« Reply #10 on: February 23, 2008, 09:24:13 PM »
Bigtime, that looks great.  You should get one of our billet timing chain covers to fit in there.
bigtimeauto
« Reply #11 on: February 23, 2008, 11:57:25 PM »
It won't fit over my timing belt Smiley
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
andyf
« Reply #12 on: February 24, 2008, 12:19:03 PM »
Well in that case you're in luck since we have stuff for belt drives as well as belt drive distributors.
bigtimeauto
« Reply #13 on: February 24, 2008, 10:59:22 PM »
hmmm, i didn't see that on your site. Do you have one for this belt drive?
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
andyf
« Reply #14 on: February 25, 2008, 04:58:35 PM »
Nope, whose belt drive is that?  That idler gear looks like it would be in the way of any TDC pointer.
I'm waaaay behind on keeping the webpage up to date.  I spend all of my free time inventing new products and I don't know much about website work so I just never mess with the webpage.  I've developed 12 new products so far in 2008 and none of them are on the website.  I probably did 30 new items in 2007 and none of them are on the site.  I need to hire some high school web geek to keep my site up to date.
« Reply #15 on: February 25, 2008, 08:49:51 PM »
That's the Aussie belt drive.  I have one too.
That One Guy
"What if it was one guy with six guns?"
« Reply #16 on: February 25, 2008, 08:55:46 PM »
is there an advantage to using belt drives over chain drives Huh
"I'm your Huckelberry"                      I need someone to look forward to.
« Reply #17 on: February 25, 2008, 09:07:33 PM »
Yes - you can adjust everything w/o taking the motor apart!
That One Guy
« Reply #18 on: February 25, 2008, 09:12:40 PM »
well, I've never had to do any adjusting on the timing chain that would require taking the motor apart, unless something bad happened that made me take the engine apart anyways Huh
« Reply #19 on: February 25, 2008, 09:47:40 PM »
Not everyone needs it.  It's a tuning tool, and also reduces harmonics more than any other timing system.  If it didn't work, Jesel would be making timing chains, not belts Wink
« Reply #20 on: February 25, 2008, 10:14:19 PM »
never seen the aussie ones before...where can you get them?
« Reply #21 on: February 25, 2008, 10:39:05 PM »
 I got mine from B1Valiant, but there are a couple places selling them.  440Source used to sell them, not sure why they quit.  Mancini carries them http://chucker54.stores.yahoo.net/mabhebe1.html
« Reply #22 on: February 25, 2008, 10:47:41 PM »
cool...thanks....i've allways used jessel belt drives  but i like the fact that theirs a tensioner on that one
« Reply #23 on: February 25, 2008, 10:52:01 PM »
Jesel doesn't have a tensioner?  Guess I never paid attention.  I got mine cheap, just need the ATI balancer with the long hub.
bigtimeauto
« Reply #24 on: February 25, 2008, 11:08:22 PM »
Not to mention a chain tends to break when there are 16 valves with 850lbs open banging on them at 8500rpm. Smiley
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
bigtimeauto
« Reply #25 on: February 25, 2008, 11:11:00 PM »
Jesel does not use a tensioner. I guess when the other companies copied the design they changed how the cam gear was tapered so they had to use a tensioner instead. maybe it was a patent thing.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
bigtimeauto
« Reply #26 on: February 26, 2008, 09:48:02 AM »
AndyF, check your pm's!
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
andyf
« Reply #27 on: February 26, 2008, 04:17:57 PM »
I checked my PM, wrote you a reply but it bounced because your inbox is full.
I wouldn't mind seeing if I could build a TDC pointer and crank trigger bracket for the Aussie timing belt setup but the placement of that idler gear does look to be a problem.  Once I have a set in my hand I might be able to figure out a solution though.
bigtimeauto
« Reply #28 on: February 26, 2008, 04:43:53 PM »
fixed!
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
ilabodyguy
Do Something...Even if it's Wrong
« Reply #29 on: February 27, 2008, 08:45:40 PM »
Mancini making a mid plate also?
Pages: [1] 2  All Go Up Print
