September 07, 2008, 12:31:58 AM
| | |-+  upper ball joint
Author Topic: upper ball joint  (Read 149 times)
x360x64dart
upper ball joint
« on: February 21, 2008, 07:37:36 PM »
 Do you need to press in the ball joint in the upper or should tightning the nut suck it through enough?
It's almost a big block! Escondido,CA
Xwaynestaticx03
Re: upper ball joint
« Reply #1 on: February 21, 2008, 10:11:41 PM »
the ball joint actually screws into the control arm. it doesnt press in. hopefully the threads arent stripped out. if they arent you should be able to put the ball joints in easily. good luck
67 dartgts
Go fast or go Home
« Reply #2 on: February 21, 2008, 10:37:24 PM »
Hello:
    Yep   agree  .
  Maynard
x360x64dart
« Reply #3 on: February 21, 2008, 10:43:05 PM »
Oh woops.  \/][ dummy! Thanks guys
x360x64dart
« Reply #4 on: February 22, 2008, 02:20:51 PM »
I'm pretty sur e they were mostly stripped out, there was just enough left to grab so i went ahead and muscled it in with a pipe wrench. It definitely didnt go in easy but  its in their solid. How far do i turn it in, stop at the last thread or go past till it bottoms on the flat?
Thanks Dustin
I know i know, i got a shop manuel on the way Blah Blah Blah
x360x64dart
« Reply #5 on: February 22, 2008, 03:09:15 PM »
 Dunno
x360x64dart
« Reply #6 on: February 22, 2008, 04:20:33 PM »
i bottomed them out on the flange, got impacient, hope that was rite!  motorinstall
doug 371
« Reply #7 on: February 22, 2008, 05:17:35 PM »
u need to torque to at least 125 foot lbs.
Allentown, PA
« Reply #8 on: February 22, 2008, 07:46:13 PM »
yup if you bottomed out the flange on the A arm yuo will be fine ....
