July 06, 2008, 07:44:23 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  Ram rim size.
Author Topic: Ram rim size.  (Read 61 times)
BIG DOG
Ram rim size.
« on: February 28, 2008, 06:53:10 PM »
Does anyone know what the offset of this rim would be?It's off a newer dodger ram 1500 16" 7" wide 5 on 5.5 bolt pattern.The mesurement that I want is from the inside bolt holes where the wheel would bolt on to the outside of the rim.
Thanks!
Gmax6
Re: Ram rim size.
« Reply #1 on: February 28, 2008, 06:58:19 PM »
   I'm not sure if this is what you mean, but  lay it flat  and put a plane across  ???the edges of the rim. Then measure from bolt hole to plane.HuhHuh??
BIG DOG
Re: Ram rim size.
« Reply #2 on: February 28, 2008, 08:03:48 PM »
 \/][ I meant the back spacing from the inside bolt holes out to the edge of the rim.Put a straight edge across the back of the rim and measure in.Your correct I believe the offset is from a center line out usually measured in mm.
I want to know what the back spacing is on this style rim if anyone has them.
Thanks!
67Dart383
Nasty Dart from Memphis, Tennessee
Re: Ram rim size.
« Reply #3 on: February 28, 2008, 09:33:47 PM »
I've got the 20inch 5 spoke on mine!
