July 09, 2008, 02:00:22 AM
| | |-+  tremac 5spd cluth pedals
Author Topic: tremac 5spd cluth pedals  (Read 92 times)
werner
« on: February 29, 2008, 04:44:40 PM »
Installed TKO 5spd. Car was automatic coverted to 5 spd. Bough complete kit from Keisler with hyd clutch.. When I mounted pedals, clutch pedal sits about 2-3 inches higher off the floor than the brake pedal. Out of adjustment on the rod for the slave cylinder. Also the stop for the clutch pedal does not hit the dash. The car is a 69 dodge charger with power drum brakes. ARe the pedals the same fpor powre brakes and standard brakes ? What gives. Anyone else have this problem. I have seen many pictures of spd pedals in B bodies but the 2 pedals seem to sit at the same heights.
