July 06, 2008, 07:33:48 PM
| | |-+  keisler clutch pedal install
Author Topic: keisler clutch pedal install  (Read 90 times)
werner
« on: February 29, 2008, 04:46:39 PM »
Installed TKO 5spd. Car was automatic coverted to 5 spd. Bough complete kit from Keisler with hyd clutch.. When I mounted pedals, clutch pedal sits about 2-3 inches higher off the floor than the brake pedal. Out of adjustment on the rod for the slave cylinder. Also the stop for the clutch pedal does not hit the dash. The car is a 69 dodge charger with power drum brakes. Ae the pedals the same for power brakes and standard brakes ? What gives. Anyone else have this problem. I have seen many pictures of 4 spd pedals in B bodies but the 2 pedals seem to sit at the same heights.
Any help wpould be appreciated.
