December 04, 2008, 01:15:05 PM
| | |-+  Anyone using a Pertronix Second Strike box?
Author Topic: Anyone using a Pertronix Second Strike box?  (Read 97 times)
MVRCorp
« on: February 29, 2008, 11:42:33 PM »
67 Dart small block. Pretty stock motor, a driver. What have you figured to be the best crank offset angle for the second hit?
chryco
Re: Anyone using a Pertronix Second Strike box?
« Reply #1 on: March 01, 2008, 08:36:39 AM »
Need more info . Cam specs , carb jetting intake , exhaust , RPM range . Will all have to be considered in your effort to achieve complete combustion.
Failing that , you could always experiment by , say 3 deg increments and use the SOPD method.
   Chryco Wink
