Topic: YAC (Yet another combo) question (Read 1116 times)
dusterdarryl
fastcars is right, your going to have trouble keeping out of the nines, should be good fun, whats the pistons part # you have? sounds like a weapon
ab7fh
440Source part # 7000 "Platinum Series Pistons 4.375 +14 Domed"
ab7fh
A couple more questions... What would you recommend for a cam gear drive, and a harmonic balancer?? There's so many choices
that crane cam would still be a good choice...milodon gear drives are very nice...ati dampners are the best
ab7fh
When I ordered my pan and oil system I told them was going to be running a girdle. They told me I don't need a windage tray with a deep pan and girdle. What are your thoughts on this?
ab7fh
From Crane's website:
"MODERATE COMPETITION ONLY, GOOD UPPER RPM TORQUE AND HP, BRACKET RACING, AUTO TRANS W/RACE CONVERTER, 12.0 MINIMUM COMPRESSION RATIO ADVISED. BASIC RPM 4400-7400"
I imagine the cam will have a lower bottom end range do to the big cubic inch motor? What kind of a stall speed would I be looking for for this cam? I had previously heard I wanted something about 3800 with gears in the 3.90 - 4.10 range using 29" tires.
ya the rpm range will be lower with more cid..it should make it's peak power at about 6300 rpm. ..a 3800 stall would work great to...the engine should make a bunch over 600ftlbs of torque so your also gona have to make sure the chassis is finely tuned
ab7fh
I've already got Caltrac bars and springs. I've widened the wheel wells and have a spring relocation kit just waiting installation. I'll be using the stock K member with engine mounts cut out and a motor plate. Stock lower control arms, tubular uppers... Even though I'm shooting for 10s, I'm going to have a full cage which will help keep the chassis under control and consistent.
I just scored a D-60 housing on Monday. It came from a van and it has extra gussets on the pumpkin. That will be narrowed as needed.
ab7fh
Another twist... I priced out all of the machine operations I want done to a my stock low deck block. It came out to about $2000. I looked at Indy's low deck block which they want $3500 for. Add $800 to the stock block for a girdle and billet mains and we're getting really close to the cost of a new aluminum block with cross bolted billet mains "stock", sleeved cylinders etc...
Am I missing anything? Has anyone heard good or bad about the Indy blocks?
ksdartguy
There was a post back a ways on Indy and KB blocks. Id lean toward the KB. They make it in a low deck height and I think you get a better finished product.
Ask speedy. Hes got an RB version of the KB.
illfish
I'd go with either KB or one of the new World/Dart?/Barton blocks. I've got INDY and my buddy has KB. The INDY block was a mess. Had to rehone, redeck, clearance everywhere, etc.
ab7fh
I just called KB and they don't make a low deck with 400 main bearing size:( Since I've already got my crank I'm screwed on that one... Indy advertises that they offer both 400 and 440 sized mains in their block.
I'll have to take a look at the others to see if they have a low deck with 400 mains.
ab7fh
Ray Barton and World show only RBs on their websites:( Dart's site says they only make Chevy, Ford and Honda stuff...
This isn't looking too good...
ab7fh
Ok. I purchased the Crane 688811 roller cam with it's recommended springs and retainers, valve locks and Teflon seals.
Next up is a set of rocker arms. I am leaning towards Harland Sharp. Any others in the same price range that are worth considering??
What do you think of the Milodon cam gear drive? Any others I should be looking at instead?
ab7fh
Well, I decided on Hugh's rocker arms.
Still looking for info about the Milodon or other cam gear drives.
pwmax
If you don;t have the Stealths already, then I would recomend using Indy EZ's, you will be MUCH happier in the long run. The Ez's will make more power with mild work, then a fully hogged on Stealth, and you don;t have to worry about a crappy heat treat.
Frank
ab7fh
I've already got the Stealth heads. I'm also not interested in over shooting my goal of a 10 sec car. Not interested in certifications, licensing and all that's needed to run a sub 10sec car.
