October 06, 2008, 07:31:24 AM
| |-+  Early A-bodies
| | |-+  Beeprace's 64
Author Topic: Beeprace's 64  (Read 1991 times)
340fyd
Beeprace's 64
« on: March 06, 2008, 10:35:48 AM »
Beeprace's bad azz 64
Lee
340fyd
Re: Beeprace's 64
« Reply #1 on: March 06, 2008, 10:39:23 AM »
2
Lee
340fyd
Re: Beeprace's 64
« Reply #2 on: March 06, 2008, 10:39:40 AM »
3
Lee
340fyd
Re: Beeprace's 64
« Reply #3 on: March 06, 2008, 10:40:00 AM »
4
Lee
340fyd
Re: Beeprace's 64
« Reply #4 on: March 06, 2008, 10:40:25 AM »
5
Lee
340fyd
Re: Beeprace's 64
« Reply #5 on: March 06, 2008, 10:40:48 AM »
6
Lee
340fyd
Re: Beeprace's 64
« Reply #6 on: March 06, 2008, 10:41:08 AM »
7
Lee
Re: Beeprace's 64
« Reply #7 on: March 06, 2008, 10:59:23 AM »
6
  is that tie rod right?  looks funny for some reason.
Re: Beeprace's 64
« Reply #8 on: March 06, 2008, 11:00:54 AM »
looks like there is an extra spacer in his.
here is mine.
340fyd
Re: Beeprace's 64
« Reply #9 on: March 06, 2008, 11:18:06 AM »
I'm not sure, he's been emailing this morning.  I figured he'd be here.  I guess the thread that he started about his old K-member wasn't a for sale ad.  If I'm not mistaken I'm thinking............Well I'd better let him tell the story.
Lee
beeprace
Small Block A Body Baby
Re: Beeprace's 64
« Reply #10 on: March 06, 2008, 12:47:57 PM »
On the early A body it takes a longer spacer. Bill accidentally sent me a short spacer, so I needed another 1/2 inch before we set up the bump steer. It took another 1/4 inch from what is the normal system for me to get the bump steer right. I really like the system compared to my old T-bar system. I can jack the car and everything goes straight up, no tires going eak eak eak. I will not get to the track till late march for test and tune.
Only changes to the chassis where Alterkation and I replaced the old Aladan rear single adjustable shocks with AFCO double adjustables. It is a 4-link car and has run as quick as 1.19 on 60 ft. That is footbraking, I have no transbrake in the car. However that was leaving at 3800 rpm. It is a real nice car and drivetrain, however it doesn't have a really wild B-1 or Indy headed small block.
My old K-frame, with KONI Shocks/Strange Hubs and Caliper Brackets, K-frame notched for Milidon pan, Mounts and T-bars are free to whomever is going to be racing an early A Body, you pick it up and buy me lunch. I guess my previous post of real cheap was thought to be a fore sale add, my apologize.
Beep Beep Out
johndart
Re: Beeprace's 64
« Reply #11 on: March 06, 2008, 07:38:38 PM »
Man that looks fantastic  !nanr
Re: Beeprace's 64
« Reply #12 on: March 06, 2008, 07:40:31 PM »
Quote
 ooooohhh  ok.. i did not know that.
dangerdawg
Re: Beeprace's 64
« Reply #13 on: March 07, 2008, 07:54:56 AM »
what nice stuff you guys have.
Ivor383
Re: Beeprace's 64
« Reply #14 on: March 07, 2008, 08:20:34 AM »
Ooh, lovin' your work, sir! Grin
Apparently, I have a 1964 Plymouth Barracuda!
beeprace
Re: Beeprace's 64
« Reply #15 on: March 07, 2008, 09:02:54 AM »
I am now down to needing 0ne 90 degree #16 fitting to finish off my cooling line before I can turn the key on her. Before I went to  Iraq the car ran a best time of 6.02 at 111.5 mph with a normal 60 ft of 1.25, it has run 1.19 on 60 ft on a great track, methanol carb and leaving at 3800 rpm. Car is a true footbrake car, no t-Brake installed. Below is a list of what is in it and what has been changed, give me some guesses on what she may pick up:
2680 lbs car and driver   (down 100 lbs)
Dana 60 5.38 gear
4 link
Coil over shocks             (replaced Aldan singles with AFCO Doubles)
Alterkation                    (it replaced stock ront end)
Wheelie Bars, used often
Strange Disk Brakes all 4 corners
14X31 Goodyear slicks, 98 roll out
3.5X26 Front runners
Polished Centerline wheels
Trick 904 transmission, all aluminum drums, billet input and output shafts, full rollerized, lightened sunshell, reverse manual valve body (A&A Rick Allison full boogie job)
Aluminum Drive shaft
Turbo Action 5800 true stall convetor
Motor: By Hensley Performance
340 block .060 over 4.100 Program Billet splayed caps
Mopar 3.79 Crank
Eagle H-Beam Rods
Ross Light Piston, 400 grams without pin, flat top .005 out of whole, giving me a .034 piton to head and 12.1 compression
Total Seal Rings
Comp Roller Cam Int. .655, 276@.050  Exh. .660 282@.050 set up on 103.5  (old cam flat tappet .575 272@ .050 .592 278@.050 set up 0n 104)
Crane roller Lifter (old comp flat)
Head are Indy edlebrock old flow was 284 cfm, new flow is 292 cfm
Trashed Old indy rockers( as they were already trashing themselves, 1 broke with 400 passes on flat tappet spring pressure, those guys just refuse to make a quality rocker) and set up a custom set of cranes, four different part numbers to make it work right, two BB stage six numbers and two BB standard head numbers, had to custom make the spacers and mill the sides on a few pedestals, best valve train geometry I have ever had.
Smith brother Push rods and adjusters
Comp 943 valve springs 245lbs on seat
Comp Ti retainers
Edlebrock Super Victor Intake (Old intake was a victor) you really can't compare these two intakes the super victor is a race intake
I have added a special Intake collector, new technology, has picked up the super stockers over a tenth and 1.5 mph
1050 gas dominator for spring and fall, 1050 alky dominator for summer, by Quick Fuels
Custom made Headers by Steve Mutakus Race Cars 1 5/8th to 1 3/4 to 2 inch with 3.5 collector, (he also installed the molly cage and had the car certified to 4.50 1/8 and 8.50 1/4, this was new while I was gone, with paint new lexan and some new aluminum work)
I leave the line at 2500 on the footbrake, shift at 6800-6900 and go thru at the same, 1/8 mile is all they run around here
The car launches forward and starts pulling the wheels about 1.5 feet, when I pull second gear it continues up another 1.5 feet, I am going to try and take a little of the wheel stand out of it. However it hooks consistant and drives so straight you could lay your hands in your lap. I hope it continues the same with the Alterkation. More to follow. Beep beep Out
6469mopar
JACKSON, NJ
Re: Beeprace's 64
« Reply #16 on: March 07, 2008, 05:30:33 PM »
 Nice combo, need more pics of the car  thank you
Mopartist
Re: Beeprace's 64
« Reply #17 on: March 07, 2008, 07:16:28 PM »
Quote
I don't suppose you ,live anywhere near central Oregon do you? (What a score that would be!)
PCH
Re: Beeprace's 64
« Reply #18 on: March 15, 2008, 11:56:30 AM »
I dig the 64!! I am working on a 65 Vailiant Race Car with an Alterk front end - back half ladder bar car with a small block.  I will post pics as soon as I can figure out how....
Re: Beeprace's 64
« Reply #19 on: March 15, 2008, 12:07:35 PM »
Ray, I just seen you were a member here. Good to see ya. I have not seen you sence you retired. I moved from the area in Nov 06. The car is looking great like allways. I wish I would have know you were looking to do the Alterkation you could have seen mine befor. Tell JD to call.
340fyd
Re: Beeprace's 64
« Reply #20 on: March 17, 2008, 10:04:49 AM »
More this thing is killer.
Lee
340fyd
Re: Beeprace's 64
« Reply #21 on: March 17, 2008, 10:06:45 AM »
2
Lee
340fyd
Re: Beeprace's 64
« Reply #22 on: March 17, 2008, 10:07:07 AM »
3
Lee
340fyd
Re: Beeprace's 64
« Reply #23 on: March 17, 2008, 10:07:41 AM »
4
Lee
340fyd
Re: Beeprace's 64
« Reply #24 on: March 17, 2008, 10:18:50 AM »
5
Lee
340fyd
Re: Beeprace's 64
« Reply #25 on: March 17, 2008, 10:22:16 AM »
6
Lee
340fyd
Re: Beeprace's 64
« Reply #26 on: March 17, 2008, 10:22:50 AM »
7
Lee
340fyd
Re: Beeprace's 64
« Reply #27 on: March 17, 2008, 10:23:21 AM »
8
Lee
beeprace
Re: Beeprace's 64
« Reply #28 on: March 17, 2008, 11:27:35 AM »
Thanks for posting these Lee!!!!!!!!!
Test and tune this Saturday if Mom Nature allows. I am ready, I have worked and polished on this thing untill ny arms are going to fall off. This thing started life as a 273, push button car back in the early 80's. Ray J. aka the beeper drag tree
6469mopar
JACKSON, NJ
Re: Beeprace's 64
« Reply #29 on: March 17, 2008, 05:02:58 PM »
WOW, THATS BAS A$$
Pages: [1] 2  All Go Up Print
