October 06, 2008, 11:30:17 PM
| | |-+  '71 Duster to '73 Front Suspension/Big-rotor Conversion
Author Topic: '71 Duster to '73 Front Suspension/Big-rotor Conversion  (Read 494 times)
Two Lane
« on: March 15, 2008, 02:40:54 PM »
1971 Duster (w/9" drums)
(Already have the '73-up Wilwood calipers & brake lines)
Where's the best place to buy
all the (new) '73-up front-end
suspension parts (UCAs, etc.)
required for the front-disc
big-rotor (11.75") conversion?
This will be a major help & *thanks* in advance!!
oldkimmer
Re: '71 Duster to '73 Front Suspension/Big-rotor Conversion
« Reply #1 on: March 16, 2008, 02:50:00 PM »
.............From Bill, ofcourse, @ ReillyMotorSports............top of page, across from ur user info............kim.........
Two Lane
« Reply #2 on: March 17, 2008, 11:26:58 AM »
We'd would've been happy to, but RMS does not sell the
specific components needed in the parts list for the swap.
Thanks for your thoughtful effort to be helpful.  --  Smiley
rjsjea
ProTouring Demon
« Reply #3 on: March 17, 2008, 12:11:29 PM »
Does anybody make NEW spindles for the 73-up swap???......Will the tubular uca's from RMS work??  Dont know if anybody makes NEW parts you are looking for Dunno
Buy tubualr uca's and the right spindle from a junkyard.............
rokketride
« Reply #4 on: March 17, 2008, 01:10:55 PM »
Someone makes new A-Body disc knuckles, very cost prohibitive IMO.  Like $300+
Two Lane
« Reply #5 on: April 03, 2008, 10:14:41 AM »
New spindles are available @ Master Power Brakes in Mooresville NC.
They are 500.00 for the pair, & come with the "special" MOOG ball-joints.
Good used '70s vintage "junkyard-parts" are not a
readily-available option in many parts of the country.
The only remaining part left to find now is the centerlink.
Thanks for each helpful reply!   Smiley
Bill_Reilly
Administrator
White Haven, PA
« Reply #6 on: April 03, 2008, 10:59:45 AM »
You'll need this list of parts...
Spindles and new spindle nut set - we have them - $350(same spindles as MPbrakes)
Lower balljoints - we have them - $89/pr ..."special" balljoints are a farce created by marketing geniuses to dupe the public into spending more money.
Wilwood caliper mount bracket set - we have them - $149
Tube uppers - we have them.(oem a-body ones are not available new, only the B/E ones.)$299 complete with upper balljoints and ends.
If your upper control arm eccentric bolts are bad, we have them for 39.80 a set. If yours are in good shape, you don't need them.
11.75 Cordoba rotors, bearings, seals, dust caps - local auto parts store, fairly cheap.
I'm not pushing for another sale, but thats the list of parts you'll need to do it, assuming you have the wilwood calipers for a 1" rotor thickness.
