Topic: '71 Duster to '73 Front Suspension/Big-rotor Conversion (Read 557 times)
Two Lane
1971 Duster (w/9" drums)
(Already have the '73-up Wilwood calipers & brake lines)
Where's the best place to buy
all the (new) '73-up front-end
suspension parts (UCAs, etc.)
required for the front-disc
big-rotor (11.75") conversion?
This will be a major help & *thanks* in advance!!
oldkimmer
.............From Bill, ofcourse, @ ReillyMotorSports............top of page, across from ur user info............kim.........
Two Lane
We'd would've been happy to, but RMS does not sell the specific components needed in the parts list for the swap. Thanks for your thoughtful effort to be helpful. --
Does anybody make NEW spindles for the 73-up swap???......Will the tubular uca's from RMS work?? Dont know if anybody makes NEW parts you are looking for  Buy tubualr uca's and the right spindle from a junkyard.............
rokketride
Someone makes new A-Body disc knuckles, very cost prohibitive IMO. Like $300+
Two Lane
New spindles are available @ Master Power Brakes in Mooresville NC. They are 500.00 for the pair, & come with the "special" MOOG ball-joints. ---------------------------------------------------------------------------------------------- Good used '70s vintage "junkyard-parts" are not a readily-available option in many parts of the country. ---------------------------------------------------------------------------------------------- The only remaining part left to find now is the centerlink. --------------------------------------------------------------------------------------------- Thanks for each helpful reply!
You'll need this list of parts...
Spindles and new spindle nut set - we have them - $350(same spindles as MPbrakes) Lower balljoints - we have them - $89/pr ..."special" balljoints are a farce created by marketing geniuses to dupe the public into spending more money. Wilwood caliper mount bracket set - we have them - $149 Tube uppers - we have them.(oem a-body ones are not available new, only the B/E ones.)$299 complete with upper balljoints and ends.
If your upper control arm eccentric bolts are bad, we have them for 39.80 a set. If yours are in good shape, you don't need them.
11.75 Cordoba rotors, bearings, seals, dust caps - local auto parts store, fairly cheap.
I'm not pushing for another sale, but thats the list of parts you'll need to do it, assuming you have the wilwood calipers for a 1" rotor thickness.
