December 05, 2008, 08:34:34 AM
| | |-+  Gutted stock hood
Author Topic: Gutted stock hood  (Read 586 times)
Wayne L
Gutted stock hood
« on: March 16, 2008, 05:16:26 PM »
Has anyone gutted thier stock steel hood like on a stock car,  for a street/strip car?  My flat hood (69 dart) was 59 pounds.  After removing the inner panel,  latch assembly, and cutting a 16 inch hole to clear my air cleaner it weighs 28 pounds.  My plan is to add a fierglass hemi scoop and try to stiffen it back up without adding back alot of weight.  A quality bolt on fiberglass hood shipped to montana is about $1000 so, I thought I would give this a try.  Any ideas  or pictures would be great.  Wayne
Re: Gutted stock hood
« Reply #1 on: March 16, 2008, 07:31:18 PM »
Post some pictures of the hood you gutted.
Wayne L
« Reply #2 on: March 16, 2008, 07:50:47 PM »
Im not sure if I can post pictures yet, new member, isnt there a certain number of posts required first?  What I have left is just the outer skin.  The four edges are still rigid, but the hood seems to twist diagonally.  Let me know.  Thanks  Wayne
Dodgeboy
« Reply #3 on: March 17, 2008, 10:09:42 PM »
I would like to see what you have done. You can upload the pictures to photobucket.com (it's free) and then link your post to them. Then they will show on your post when we look at them.
Thanks,
Roger
« Reply #4 on: March 17, 2008, 11:25:10 PM »
or just make 5 more posts. Just post a few smileys.
Think3205
A work of art in progress...
« Reply #5 on: March 17, 2008, 11:28:01 PM »
 Popcorn
BBLM23
Poughkeepsie, NY
« Reply #6 on: March 18, 2008, 06:40:56 AM »
I have a gutted stock hood and deck lid on the K, I hate them. Still not that light and very flimsy.
Walter
1981 Dodge Aries 451 B1/BS
Best 1/4 9.871 at 136.01mph
1969 Dart Swinger 431 B1/BS
Best 1/4 10.649 at 126.45mph
Racing Pro in street trim.
1981 Plymouth Reliant 400
Wayne L
« Reply #7 on: March 18, 2008, 10:24:49 AM »
I talked to a local guy that builds stock cars and he explained how to do this using 1/2" square tubing.  Im picking up the steel today and will try to post pictures tonight.  Wayne
« Reply #8 on: March 18, 2008, 10:56:26 AM »
I did this years ago with another car.  we cut all but the entire framing out.  theyre very flexy, noisy and get bent and stay bent.  not to mention it always felt like it was going to be ripped off the car at speed.
if you treat it like a cheapo lift off fiberglass hood they last a bit, but seems they almost have to have some sort of reinforcement to them.
doubt Id ever do that again, at least not to that extent
« Reply #9 on: March 18, 2008, 07:53:05 PM »
ever thought of glassing your own hood? or making a carbon fiber or fiberglass inner shell? Fiberglass you only need resin and the sheeting, and you'll have to make a mold of the inner structure. Carbon fiber is nice and light but you need to do a more specific way of curing it.
-46 Fargo
oldkimmer
« Reply #10 on: March 18, 2008, 08:56:15 PM »
..................I have a gutted hood on my duster, I use a prop rod to hold it open, took the springs off of the hindges...I have hood pins also, but need to add a 3rd 1 in the center as it bows up at speed.....as the big hemi scoop sucks in alot of air...I wouldnt do it again without some kind of bracing.......kim.........
Wayne L
« Reply #11 on: March 18, 2008, 09:21:36 PM »
I have a couple pictures to try so here goes.
Wayne L
« Reply #12 on: March 18, 2008, 09:22:48 PM »
Post 8
Wayne L
« Reply #13 on: March 18, 2008, 09:23:36 PM »
Post 9
Wayne L
« Reply #14 on: March 18, 2008, 09:24:27 PM »
Post 10
Wayne L
« Reply #15 on: March 18, 2008, 10:35:16 PM »
So here is my hood with the bracing installed.  It's 1/2" X 1/16" wall square tubing.  This worked out suprisingly well, almost all the twisting is gone.  Im also going to run beads of panel adhesive to bond the bracing to the hood skin, which should help even more.  The hood is now 35 lbs.   Tomorrow I will order the hemi scoop.
Wayne
Wayne L
« Reply #16 on: March 18, 2008, 10:37:45 PM »
Here is another angle.
satellite65
« Reply #17 on: March 18, 2008, 10:43:28 PM »
That looks NICE!
mrspeeddemon
Great Falls, MT
speeddemonrodsteration
« Reply #18 on: March 19, 2008, 01:58:07 AM »
where are you located int mt?- I'm in great falls -glad to see theres another a body freak around!! !nanr
Save the trees, BURN RUBBER!
my car- check it out!
« Reply #19 on: March 19, 2008, 12:31:04 PM »
That looks great! how did you get the bracing out without bending up the skin?
Another idea, how abount welding in some plates where the hood pins will go, that might help keep it on.
Wayne L
« Reply #20 on: March 19, 2008, 07:21:32 PM »
Thanks for the input.  To answer some questions I live in Bigfork Montana, north end of flathead lake.  The inner panel actually came out easy.  I drilled out the spotwelds around the perimiter and the 40 year old seam sealer was already seperated.  I like the idea of reinforcing the pin locations, good idea.  I would also like to modify the hinges to keep it bolt on, pin front.  The scoop is weeks out so I have some time to still work on it, I might have it soda blasted to clean it up a little better.  The 1/2" tubing was easy to bend, I tack welded a peice of 1 3/4" pipe and 6" well casing to my bench.  I used the inside edge of my fenders and cowl to check the shape of my bends so the hood would match.  I can't say for sure how well this will to work until its back on the road, but its better than I expected so far and about 25 pounds lighter.   Wayne
