December 05, 2008, 08:30:48 AM
| | |-+  rear firewall
Author Topic: rear firewall  (Read 1280 times)
digler
DRIVE LIKE LIGHTNING CRASH LIKE THUNDER!!!!
rear firewall
« on: March 17, 2008, 02:04:51 PM »
anybody install a rear firewall yet , did you remove the rear seat cross braces ? any pictures would be helpfull
or how about a universal firewall unit from jegs or something?
Think3205
A work of art in progress...
Re: rear firewall
« Reply #1 on: March 17, 2008, 02:07:33 PM »
nope but i need too...  Popcorn
Re: rear firewall
« Reply #2 on: March 17, 2008, 04:44:39 PM »
no need to remove the braces, just use some sheet metal over the braces and screw it in at the corners
Re: rear firewall
« Reply #3 on: March 17, 2008, 05:49:52 PM »
this is set on the braces for the seat and screwed in,it's in 3 pieces including the package tray.
i still need to fix the wheel wells and paint it dark grey,the aluminum makes too much glare in the window.
i can make a template of this easily to get you started if you want.
Re: rear firewall
« Reply #4 on: March 17, 2008, 05:50:05 PM »
This is b569RR. If you look at his gallery you can see all.
Re: rear firewall
« Reply #5 on: March 17, 2008, 11:30:35 PM »
Thanks Cary. And the back seat fits.  Cheers
oldkimmer
Re: rear firewall
« Reply #6 on: March 18, 2008, 09:00:37 PM »
...........................If u have a battery and or fuel cell in the trunk the firewall has to b sealed all the way around so nothing can leak into the passenger compartment in the event of an accident..........kim............
wild383
Wild383@live.com
Re: rear firewall
« Reply #7 on: March 18, 2008, 10:55:54 PM »
With the battery and a fuel cell in the trunk like me, sealing off the trunk from the drivers compartment is a very good idea.
sunsetdart
us4ever365@hotmail.com
Re: rear firewall
« Reply #8 on: March 19, 2008, 07:49:56 AM »
If you are going to race it,and the battery and fuel cell are in trunk, NHRA rules state that if its aluminum it must be .025"....if its steel I think it must be .090" . Not sure about the steel , so check rule book.
Re: rear firewall
« Reply #9 on: March 19, 2008, 09:15:07 AM »
I'm pretty sure if it's aluminum it needs to be thicker than if its steel.  I think its like .024" for steel and .032" for aluminum.
Re: rear firewall
« Reply #10 on: March 19, 2008, 10:02:02 AM »
I was reading that a firewall in the rear actually helps the torsional rigidity of the chassis. If that's true, maybe welding in a steel firewall is the way to go?
Re: rear firewall
« Reply #11 on: March 19, 2008, 10:03:13 AM »
 agree   those numbers sound correct
Dartdragracer
Re: rear firewall
« Reply #12 on: March 19, 2008, 01:15:01 PM »
I'm currently installing a .040 thick aluminum rear firewall in mine. I will post pics when its done.
you can buy the sheets of aluminum in various colors so no need for paint.
Keep the seat braces, they make the good attachment points and add support.
jackie
Re: rear firewall
« Reply #13 on: March 19, 2008, 01:57:48 PM »
yes, you can get color's.. i like the black inside,white outside. it looks clean under the car,but in this pic. mine sure is dirty inside.it is easy to clean.
Dartdragracer
Re: rear firewall
« Reply #14 on: April 04, 2008, 07:59:24 AM »
I got mine finished last night, Here is a pic, It is screwed to the seat cross members. I used the black rubber edging to cover all the edges that would otherwise be exposed.
gt
Re: rear firewall
« Reply #15 on: April 04, 2008, 10:58:14 AM »
So if it has to be sealed, is it ok to have speakers mounted in the package tray and pass tech inspection.
gt
That One Guy
An American from America
Re: rear firewall
« Reply #16 on: April 04, 2008, 12:14:30 PM »
I've got the blue and white in mine, I think it's .035 aluminum, it was easy to do, and we left the braces there, and it wouldn't take anything to put the seat in if I was going to.
"I'm your Huckelberry"
Dartdragracer
Re: rear firewall
« Reply #17 on: April 04, 2008, 12:56:48 PM »
They do not have to be completly sealed or leak proof to pass tech. A factory rear seat wil pass tech with no barrier and the fuel/battery in the trunk. The barrier is to protect from a flash fire from the trunk.
Re: rear firewall
« Reply #18 on: April 04, 2008, 04:23:39 PM »
gt
you can put speakers in but they have to be boxed in from the rear.the speaker is made of paper and won't pass tech.
gt
Re: rear firewall
« Reply #19 on: April 04, 2008, 06:22:21 PM »
Got it, makes sense, thanks.
One other thing, if I understand correctly, if you have back seats installed you do not need to seal the rear firewall? True or False.
gt
Re: rear firewall
« Reply #20 on: April 04, 2008, 11:17:08 PM »
gt
False
If you run a fuel cell in the trunk, you need a firewall of 024 inch steel or .032 inch aluminum.  If you relocate the battery, you need to insolate it from the driver with either a rear firewall, or a sealed battery box.
Dartdragracer
Re: rear firewall
« Reply #21 on: April 05, 2008, 08:52:16 AM »
I raced at 4 different tracks with a fuel cell /battery in my trunk with no rear firewall, just the factory back seat. Tech inspectors never said a thing about it.
GTS225
Re: rear firewall
« Reply #22 on: April 05, 2008, 09:03:15 AM »
Most of us can write something like this.  The truth is that we all could find examples of differing interpretations of the rules by different "inspectors".
If one reads the NHRA rulebook for themselves, I suggest they would find that it means what it says......move the battery, seal it from the driver. (Box or firewall.)  Run a fuel cell, run a firewall.  Most of the rules are about driver safety, and a rear firewall is about keeping you alive.
My slant drag car is slow, but that doesn't mean the guy in the other lane can't get out of shape and run into me.  Therefore, I build by the rules.
Roger
Re: rear firewall
« Reply #23 on: April 05, 2008, 01:05:27 PM »
Roger
words to LIVE by
Dartdragracer
Re: rear firewall
« Reply #24 on: April 05, 2008, 02:47:47 PM »
Roger
I totally agree its about drivers safety, thats why I installed an aluminum rear firewall in mine. All I was saying was that it "will" pass tech with the rear seat and not metal barrier.
At least in miy case, it did at 4 different tracks, while I had that set up.
krabysniper
Re: rear firewall
« Reply #25 on: April 07, 2008, 06:36:41 AM »
Your car may have passed tech at those 4 tracks but I would be willing to bet if there had been an accident involving your car and a fuel fire, there would have been a tech inspector who wouldn't be doing inspections anymore, not to mention the potential lawsuit that those inspectors opened those tracks up too. A signed waiver saying you except the responsibility of potentially killing yourself wont save them from legal repercutions if you kill yourself because of something they were supposed to be looking for and preventing.
The rules in the NHRA rulebook are very clear on the subject, no interpretation needed
"All fuel tanks must be isolated from the driver's compartment by a firewall completely sealed to prevent any fuel from entering the driver's compartment."
Anyone who cuts corners when it comes to safety, almost always suffer for it in the long run (or cause others who care about them to suffer) Safety first, always!
GTS225
Re: rear firewall
« Reply #26 on: April 07, 2008, 05:29:17 PM »
Hmmmm....the tone of this response makes me think my response was a bit blunt, and it probably was.  I'm that way a lot.
Allow me to put it another way;  The rules say you're supposed to build it "X" way, and you build it the way you interpret it.  Your local track "inspectors" allow it to pass, and you think you're good.  Now you decide to make a long pull to a big event, only to have those inspectors at that national meet say, "Not on THIS track".  Now, thanks to the incorrect judgement of your local techs,( and maybe some of your error), you're out a lot of time and fuel costs.
I suggest it's better to over-engineer a bit than suffer the consequences of a mis-interpretation.
Roger
wild383
Wild383@live.com
Re: rear firewall
« Reply #27 on: April 08, 2008, 02:52:14 AM »
 agree Even though my car will be 99% street. Over engineer on the side of safety, "You'll live longer". Willie
rharveysr
Re: rear firewall
« Reply #28 on: April 08, 2008, 04:49:18 PM »
Over engineering when it comes the safety of my son...is not a question...its a standard!
Think3205
Re: rear firewall
« Reply #29 on: April 08, 2008, 04:57:34 PM »
hey Rick, are you guys going to be putting in a rear firewall?
Pages: [1] 2  All Go Up Print
