July 09, 2008, 08:09:29 AM
| |-+  Early A-bodies
| | |-+  64 Barracuda's
Author Topic: 64 Barracuda's  (Read 1256 times)
snowman
64 Barracuda's
« on: March 24, 2008, 12:11:04 AM »
I have noticed a few references to 1964 Barracuda's here, and it makes me wonder.... How many 1964 Barracuda owners are here?
Would be curious as to how close the VIN numbers are.
LILBLUE65
Re: 64 Barracuda's
« Reply #1 on: March 24, 2008, 01:07:58 AM »
Big range, 23 433 produced. It is possible though. My good friend had a B5 70 Challenger RT sold new at Prince Albert Dodge in Edmonton AB. He met a fellow in Thunder Bay years later with a B5 70 Challenger RT as well and the funny thing was that the VINs were one digit apart. We could not believe that these two cars were born right next to each other and then met again years 20 years later.
Rob
snowman
Re: 64 Barracuda's
« Reply #2 on: March 24, 2008, 02:12:09 AM »
Guess I goofed that one up. I originally intended to mention that I have a 64 and I was curious as to how many others on the board own them. According to VIN decoders found on the web the last six digits were the production sequence number. With only 23,433 being built (5 digits) why would they use a 6 digit sequence number? And from what I have found the sequence number started from 100001. Just curious, I guess.  Grin
LILBLUE65
Re: 64 Barracuda's
« Reply #3 on: March 24, 2008, 02:39:34 AM »
I think that the first # in the sequence is specific to the plant the built the car.I do believe that on the early valiant and barracuda website there is some info on that. I'll have to find it.
Rob
LILBLUE65
Re: 64 Barracuda's
« Reply #4 on: March 24, 2008, 02:56:08 AM »
All Hamtramck sequence numbers start at 500001 (for theValiant/Barracuda/Dart models only), and the Los Angeles and St. Louis plant sequence numbers start at 100001, as do all other passenger cars built at the Hamtramck plant.
Rob.
Ivor383
Re: 64 Barracuda's
« Reply #5 on: March 25, 2008, 09:11:56 AM »
Well, I have one! There are very few here in the UK, but they were no where near as popular as the 67 and later cars.
Mine was imported in 1968, pulled apart about 20 years ago and I've bought the whole thing in boxes! If it was totally original and unmolested, it would be worth restoring. but this one is getting the big block treatment! motorinstall
Apparently, I have a 1964 Plymouth Barracuda!
Detroit Iron
Buy American... ALWAYS!
Re: 64 Barracuda's
« Reply #6 on: April 18, 2008, 07:43:25 PM »
I've got a '64.  340, 4-speed (just built an Overdrive for it), big car brakes and axles.  The VIN is V442687996.
1964 Barracuda 340 4-speed
1964 Polara 500 383 A/T
1967 Barracuda 273 Commando A/T A/C
racingsnake440
Re: 64 Barracuda's
« Reply #7 on: April 27, 2008, 09:53:42 PM »
Hey Detroit Iron, nice looking '64! What throwout bearing is that on the trans?
Detroit Iron
Re: 64 Barracuda's
« Reply #8 on: May 06, 2008, 08:52:28 PM »
It's a Tilton.  I had a Keisler, but it failed after about 150 miles.
Ivor383
Re: 64 Barracuda's
« Reply #9 on: May 09, 2008, 08:19:42 AM »
Well, my '64 Barracuda has arrived from the wilds of Scotland...I've got all the parts (I think!) and it's getting a 500 stroker, 727 and narrowed 8 3/4"... looks like I've got some work to do! Shocked
tony GTS
Higher Performance
Re: 64 Barracuda's
« Reply #10 on: May 09, 2008, 02:57:14 PM »
these european mopars are too cool
tony GTS
Higher Performance
Re: 64 Barracuda's
« Reply #11 on: May 09, 2008, 02:57:39 PM »
are there any mopars in greece or italy
Ivor383
Re: 64 Barracuda's
« Reply #12 on: May 10, 2008, 07:09:18 AM »
There's a Barracuda on the Greek Island of Zakynthos! Grin
fstfish66
Re: 64 Barracuda's
« Reply #13 on: May 16, 2008, 02:08:32 AM »
detroit,,, tel me about that tilton please,, i currently run a tilton,,but so very different,,and getting ready to tear it apart to see what failed,,,10 years,,7000 miles,, tilton nascar hyd bearing
how does it attacch ? slf adjusting ?? part number ?? ill look it up if they have a web site,, thanks,,
1966 barracuda blown 340 4 speed tubbed 33x22
1940 dodge street rod hemi with A/C
2002 cummins ram dailey driver
pishta
Re: 64 Barracuda's
« Reply #14 on: May 20, 2008, 04:01:38 PM »
Rob.
Whoa...Do I have the first one??? Its a '65 model year Formula "S" built in 64. VIN 5540100001, number on radiator support? Seems odd an "S" would be the first down the line for 65...too bad I hacked the inner fenders....
bought it a copper color but the plate said it was silver coded paint so I went back to silver.
Detroit Iron
Re: 64 Barracuda's
« Reply #15 on: June 18, 2008, 04:01:46 PM »
It's taken me a while to come up with the Tilton info, but here it is.
I started with Keisler.  Long story short... after two kits and lots of money, it's in the land fill.  I went with Tilton this time.  The setup is made of a threaded bearing retainer 61-617, and the hydraulic release bearing 61-601.  I bought this stuff from Summit.  The transmission I am using is an overdrive with a CenterForce 10 1/2" clutch.  The photo in my entry above shows the Tilton setup mounted on the input shaft.  I'm not quite done with the project.  I still need to install shift rods.  So far, this project has been much easier than the Keisler kits.  I've got the system bled, and it works like butter!
I've had this car 14 years now, and I'm learning in all this that 64-65 A-bodies have a specific shifter plate.  Does anyone have a photo of the shifter coming through the tunnel hole?  I'd like to see it for reference.  Jamie Passon tells me that a second generation plate will position the shifter toward the rear of the car possibly causing interference with the floor tunnel.
Here's the photos of the project so far.
