Topic: What size bolts (Read 106 times)
mopowers
What size bolts are used to attach the trans to the motor? I need to go get some for mock up. Thanks!
Dartdragracer
I'm pretty sure they are 3/8-16 x 1 1/2", someone please correct me if I'm wrong. You might as well buy a good quality Grade 8 bolt the first time, just don't torque them for mock-up.
motorhead
thats right 3/8-16 should be 5 in from the bellhousing ,,1 in on pass side from motor to bell housing and then the starter uses 7/16
jet-taz
go to your chrysler dealer and order 4 no 6027865 and 2 no 6024863 these are the correct bolts for the trans as two outer ones are longer should cost you around 12.00
mopowers
Thanks for the responses guys. go to your chrysler dealer and order 4 no 6027865 and 2 no 6024863 these are the correct bolts for the trans as two outer ones are longer should cost you around 12.00
I will check those part #s out. I can't imagine spending a whole lot for the correct bolts though. I may as well get some grade 8s from the hardware store. We'll see what the dealer gives me for prices.
jet-taz
i know it seems alot but buy the time you fine the correct sizes, then playing around with correct head size ( there's little room now to get wrench/socket ) then correct washers see where i'am going
thanks for those part #s
68 Valiant 2 door Sedan still a / 6 but soon a  ,68 Chrysler 300 Convertible 440 auto, 65 plymouth satellite 440 auto 05 ram 3500 Cummins, 05 Magnum 3.5L grocery getter
mopowers
I just checked on those part #s. My local Dodge dealer wants about $40 for all 6. I think I'm going to check the hardware store.
Does anyone have the lengths?
jet-taz
your dodge dealer is a crook even at list cost should be 13.76 + tax 4.short ones are1 1/2, 2 long ones are two
mopowers
The short ones are $5.50 and the long ones are 8.something apeice! F-that!
