hi all!!!here is my question!!!! im currently building myself a 1968 monaco 500 convertible(about 4200lbs with me in it)....here is the specs....383 .030 over...stock crank polish and new bearing...
edelbrock 7194 camshaft: Duration at 0.006" Lift: Intake: 300° Exhaust: 308°
Duration at 0.050" Lift: Intake: 238° Exhaust: 246°
Lift at Cam: Intake: 0.320" Exhaust: 0.330"
Lift at Valve: Intake: 0.480" Exhaust: 0.495"...with matching valves springs....edelbrock double roller timming chain...edelbrock torquer aluminium intake.....edelbrock 750 cfm performer series....full length hedman headers 1 7/8 ..3'' out....440source aluminium heads(2.14 1.81 valves milled to 80cc) ....keith black dome pistons..(6cc dome)...10.1cr.....2500 torque stall(stall at 2900 rpm)...freshly rebuilt 727 with b&m transkit(shift kit)...3.91 rear gear with locker lock right ok....i know for the camshaft and you are all right!!!!i ve just buy it too fast without asking to anyone before buying it....my bad so....now i want to buy another camshaft.....im looking for that one....
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Part Number: CCA-21-224-4
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,000
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.491 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.491 exh. lift
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 1-bolt
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: CRB XE274H-10
what do you guys think of that?
and also.....do i have to buy the cam and lifter kit or just the cam????do the comp cams will works with my edelbrock lifters?
thanks all....i know its a bit long text but i dont want to do any others mistakes in my build!! thanks
