October 12, 2008, 02:19:19 PM
| | |-+  b569rr's 8 pt bar
Author Topic: b569rr's 8 pt bar  (Read 1935 times)
b569rr's 8 pt bar
« on: March 29, 2008, 09:22:33 PM »
Seeing Andy's post got me motivated. I'll post some pics if it helps you with your project. I have the S and W 8 pt with pro street down tubes. These tubes allow you to keep the back seat. I got the steel kit because I'll throw the savings over Moly at my stainless exhaust. That will be tigged
Form the sill plates with oxy acetylene torch and a 2" pipe for contour
Down tubes are tacked to B hoop.
hoop follows the angle of the B pillar window approx 5 to 7%. B hoop is as close the the factory bucket seat as practical.
Tubes and plates are tacked to trunk.
Drill a 2 1/2" hole in the floor; one per side. This allows you to lower the hoop through the floor to get 100% weld on the down tube to B hoop. The other holes are body floor plugs. Thanks for the idea Bob Shingler.
Head lines also will be replaced but having it in helped get it as high as possible. The roll bar pad should be right at the headliner.
Also, poor boys notcher works sweet.
Re: b569rr's 8 pt bar
« Reply #1 on: March 29, 2008, 09:24:47 PM »
Nice.
« Reply #2 on: March 29, 2008, 09:26:56 PM »
Break tacks loose on all 4 plates.
Lower the B hoop down through the floor.
Weld top tubes.
I went two pass uphill
6469mopar
JACKSON, NJ
« Reply #3 on: March 29, 2008, 09:27:26 PM »
looks good
« Reply #4 on: March 29, 2008, 09:31:34 PM »
A friend of mine told me to make these gussets. Hypotenuse measures 2.25". I think he said if used they must be a minimum of 1.75" on the unwelded side.
« Reply #5 on: March 29, 2008, 09:36:32 PM »
Set the bar on the plates and weld the B hoop and down tubes up. Two passes on the tube to hoop (hot root and cover).
trunk
I am going to weld in some outriggers under the plates, but do not intend to penetrate the floor.
Now time for some brew and I'll get back on it tomorrow.
« Reply #6 on: March 29, 2008, 09:39:17 PM »
Tom, I'm not really up on the NHRA rule book, but I had a guy working for me years ago that was. He ran a Super Gas dragster. I remember him telling me never to polish a weld on a roll bar. The welds had to be visible. Yours look spectacular. I don't think you'll have a problem.
Think3205
A work of art in progress...
« Reply #7 on: March 29, 2008, 09:39:27 PM »
looks great Tom! your work never ceases to amaze me...  !nanr
« Reply #8 on: March 29, 2008, 09:42:39 PM »
Tom, did you weld the openings in the rear to access the rear quarter windows closed? How will you install the glass? Or is it an optical illusion?
« Reply #9 on: March 29, 2008, 09:53:35 PM »
I didn't weld the side openings, just an illusion.
I hit the welds with a 4 1/2" stringer bead wire wheel. I did it out of habit. All our welds on the job (pipe) get wire wheeled prior to inspection. But afterwards, I thought oops; I wonder if this is considered grinding?  hammer
If I have a problem at tech, I will walk the cup over the weld with the tig torch and all will be good.
Swing out bars http://www.bigblockdart.com/index.php/topic,28410.0.html
« Reply #10 on: March 29, 2008, 09:55:38 PM »
No, you're just not supposed to grind the weld. Ever see that polished stainless cage in Rick Dobbertin's J2000? As cool as that is, it would never pass tech. Every joint in it is smooth.
« Reply #11 on: March 29, 2008, 09:58:56 PM »
« Reply #12 on: March 29, 2008, 10:16:15 PM »
Tom - your welding makes me want to throw mine in the river.
A13Dart
Minnesota
« Reply #13 on: March 29, 2008, 10:47:30 PM »
No grinding on the welds Tom, wire wheel is fine.  The nhra inspectors just want to be able to see the welds.  Shoot, they'll probably take pictures of yours.   Cool
72 Swinger 394/727/8.75
« Reply #14 on: March 30, 2008, 12:38:21 AM »
I am with Carter......Lets see how big a splash my 72 Swinger makes.....Look out below!
« Reply #15 on: March 30, 2008, 12:59:17 AM »
Thanks guys. I'll get more pics in as it progresses. I promise the tig the exhaust for you. The price of the steel S and W kit was just too affordable.
Ace
« Reply #16 on: March 30, 2008, 12:59:32 AM »
Looks awesome!  Very nice job.
Ballz Deep Racing
Where Enough is NEVER Enough
www.midamericamusclecar.com
« Reply #17 on: March 30, 2008, 01:01:54 AM »
Nice work Tom.
oldkimmer
« Reply #18 on: March 30, 2008, 03:54:20 AM »
.......................Kachicka, Kachicka.......KACHOW.........KIM............
« Reply #19 on: March 30, 2008, 07:10:45 AM »
i know i sound like a broken record but man those welds are incredible..  nice work as usual.
« Reply #20 on: March 30, 2008, 09:09:44 AM »
Good job Tom, looks killer as usual.  Can't go wrong with the SW kit, that is what I started with as well.  Very nice fit (I think) for the money allowing the usage of the interior.
Also, I have been hitting mine with a wire wheel.  Should be fine, just don't use a hard disk!   Lips Sealed
68 HEMI GTS
« Reply #21 on: March 30, 2008, 09:37:21 AM »
nice work, looks like your one hell of a fab guy!
dangerdawg
« Reply #22 on: March 30, 2008, 09:38:07 AM »
splooosh,........... there goes mine.
Go Phillies!
« Reply #23 on: March 30, 2008, 10:12:43 AM »
showoff
« Reply #24 on: March 30, 2008, 10:30:27 AM »
...dam she's  going to be  able to launch into orbit....for "2012".....     Wink  nudge nudge.........
!nanr
« Reply #25 on: March 30, 2008, 12:12:55 PM »
The speaker holes in the package tray line up pretty close with the rear sub frames.
« Reply #26 on: March 30, 2008, 12:26:36 PM »
I must agree with everyone, this looks great.
« Reply #27 on: March 30, 2008, 02:17:27 PM »
Looking good ... so when you coming east to weld mine up for me ?    duster
« Reply #28 on: March 30, 2008, 02:53:44 PM »
Great work Tom!
« Reply #29 on: March 30, 2008, 03:22:15 PM »
Definitely want to two pass this joint. Although the fit is good, the Vee is deep.
Pages: [1] 2  All Go Up Print
