December 01, 2008, 01:36:58 PM
| | |-+  Ride height
Author Topic: Ride height  (Read 303 times)
MoparKid
Ride height
« on: February 24, 2006, 11:54:26 PM »
Hello all,
           I was wondering what is the correct way to measure right height in the front and rear also, does anyone know what the factory ride height is on a 69 dart with a  /6 ?  Im curious beacuse my k-member bottoms out on everything even the little tire stoppers blocks in parking lots  \/][ . So any info would be appreciated thanks a lot.
Re: Ride height
« Reply #1 on: February 25, 2006, 12:23:51 AM »
The factory measured ride height in a wierd way (to me anyway). It was the difference to the ground from two points (the end of the lower control arm and below the pivot point on the LCA). I try to put about an inch between the LCA bumper and the frame rail. It doesn't surprise me that you are bottoming out with /6 torsion bars.
mrhotrod
Chicago,IL
mrhotrod1964@hotmail.com mrhotrod1964
Re: Ride height
« Reply #2 on: February 25, 2006, 12:24:13 AM »
1968-69 all height is 2 1/8th + or - 1/8th inch
To set ride height:
1. Jounce car several times release it on its downwards motion
2.Be sure all foreign material is cleaned from both the adjusting blades andthe steering knuckles.
3.Take first measurement "A" from the lowest point of the adjusting blade to the floor. Then measurement "B" from the lowest point of the steering knuckle arm to the floor. ( do one side of car at a time )
4.The difference between A and B is the front suspension height. NOTE "A" should always be higher than "B"
Anything else feel free to ask.
1972 Big Block Scamp 9.80 @ 138mph
2006 Cummins Turbo Diesel Ram 4x4 Dually
1966 Plymouth Valiant Big Block Project Car
Re: Ride height
« Reply #3 on: February 25, 2006, 12:27:04 AM »
Now you see why I like my method......................
mrhotrod
Chicago,IL
Re: Ride height
« Reply #4 on: February 25, 2006, 12:36:38 AM »
another thing you could do is what I did scrap the torsion bar suspension and go with the best a RMS alterktion!!!
MoparKid
Re: Ride height
« Reply #5 on: February 25, 2006, 02:23:06 AM »
Alright as long as its not suprising you B.B.D. god ha ha  Grin I'll see how she acts with some bigger ones thanks for your help!  thank you
jamesdart
Re: Ride height
« Reply #6 on: February 25, 2006, 09:56:17 AM »
what size tires do you have on it? if you have little tires, the k frame will be low to the ground.
MoparKid
Re: Ride height
« Reply #7 on: February 26, 2006, 04:02:17 AM »
Umm not sure... stock?   lol bash I also think my dead shocks and sloppy suspension would play a key part in it, but I was just curious on factory ride height.
