Topic: crank failure - update with pictures (Read 993 times)
illfish
Good point moparteacher. I would think the front main bearing would have increased wear in the direction towards the alternator?
d55dave
Stopped by the machine shop tonight - he has my new forged crank as well as most of the other parts I need. I had to pull one head to take out a piston assembly, the balancer needs one piston and rod to weigh for the balancing - something to do with needing to know the bob weight to balance the new crank.
Hopefully should be up and running in two weeks. The eagle forged crank looks great. I havent seen a credit yet but it sounds like Eagle is going to credit me the cost of the cast crank towards the forged.
Ill keep you posted.
Good thought on the belts - I am pretty sure they were not overly tight. If you think about it when the engine is spinning the timing chain is also pulling up on the front of the crank. I find it hard to believe that overtightened belts would cause a crank failure behind the front main, but who knows?
Not pointing a finger, but over-tightened belts are known to break off cranks.
I would have thought that it would have broken forward of the main. Also, you would expect that an aftermarket crank would have more strength than stock too.
glad to hear it ... keep us posted on your track times ....
68 Valiant 2 door Sedan still a / 6 but soon a  ,68 Chrysler 300 Convertible 440 auto, 65 plymouth satellite 440 auto 05 ram 3500 Cummins, 05 Magnum 3.5L grocery getter
tnplumber
Glad everything worked out for you. That could have been very costly. Hope it was just a fluke.
Scott
