July 06, 2008, 08:33:52 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  crank failure - update with pictures
Author Topic: crank failure - update with pictures  (Read 1080 times)
d55dave
« on: April 02, 2008, 09:36:21 PM »
So I left work today, pulled onto the highway and went through first, second and third to 6 grand. The best stress releif there is when leaving work! When I came to stop and go traffic I noticed a very heavy vibration in the engine accompanied by a growling noise. When I pulled over and looked the crank pulley was wobbling around. After taking off the belts I noticed the pulley, dampner and forward part of the crank are all loose. I suspect the crank fractured just behind the timing gear. It is an Eagle 4" cast stroker crank (408). I will let you all know more when I pull the timing cover, etc. Has anyone heard of this before?
What a bummer!
Re: crank failure
« Reply #1 on: April 02, 2008, 09:37:44 PM »
I've broken the balancer hub on a 440 and seen broken cranks in stroker marine engines. Anything and everything is possible.
Re: crank failure
« Reply #2 on: April 02, 2008, 09:40:39 PM »
bummer.maybe its just the bearing Dunno
67dartgt
Re: crank failure
« Reply #3 on: April 02, 2008, 10:05:53 PM »
"heavy vibration followed by a growling noise..." Yup. I had that happen. Sounded just like that when I broke the crank in my 318. Although, I only got to run it for another 10 minutes trying to figure out what was wrong with it before the engine stuck.
Think3205
A work of art in progress...
Re: crank failure
« Reply #4 on: April 03, 2008, 03:30:01 AM »
damn that's no good! i have that crank too! let me know how it turns out,hopefully it's not as bad as you think...
440Ken
You got a 440 in that? Spring Hill, FL
Re: crank failure
« Reply #5 on: April 03, 2008, 03:54:24 AM »
Sounds like what happened to me many years ago. At the time I had the original 318 in the Swinger. Cruising down the highway at 70mph a bad vabration starts...pull off to the side and open the hood and the crack pulley is wobbling. Turn off engine and the pullies, balancer and about three inches of the crankshaft fall to the ground......all still bolted together.
chryco
Re: crank failure
« Reply #6 on: April 03, 2008, 07:29:28 AM »
I`ve heard of and seen that too , only this was a factory forged crank on a 318 .
  The guy that had it was revvin' the bag of the thing , wasn`t too surprising .
     Chryco Wink
Hemi Darts Rule !!!!!
d55dave
Re: crank failure
« Reply #7 on: April 03, 2008, 10:30:02 PM »
I pulled off the timing cover tonight. The break in the crankshaft is just behind the front main bearing. I can feel it with my finger but cannot see it yet. This weekend I will pull the engine and take the crank out to inspect the damage. I emailed Eagle and they say they have had no repeated problems with this crank but want me to give them a call tomorrow. I will keep you posted.
David
Adam
adampietkiewicz@hotmail.com
Re: crank failure
« Reply #8 on: April 04, 2008, 05:48:14 PM »
Sorry to hear about your little hiccup, Dave...git 'er back on the road ASAP
motorinstall 4 speed
Re: crank failure
« Reply #9 on: April 04, 2008, 06:41:35 PM »
if a broken crank is just a hicup I'd hate to see what a real problem is.
19swinger70
Re: crank failure
« Reply #10 on: April 04, 2008, 06:57:28 PM »
i think the only thing after a broken crank is a nice picture window in the block. my condolences for your crank.
d55dave
Re: crank failure
« Reply #11 on: April 04, 2008, 07:25:44 PM »
Had I kept it runninrg I have no doubt it would have been catastrophic. If I am lucky I can get away with just bearings and a crank, timing set and gaskets...... wil have to wait and see. due to the way it broke it was still driving the timing chain, no valve to piston damage I hope.
I spoke to Eagle today and they thougth I was pushing the limits of the crank, they said the cast 408 crank is good to about 500 horse. I figured I am somewhere between 400 and 450. They say they will not leave me hung out to dry when it comes to warranty - I am hoping they credit me some value towards a forged crank.
David
Adam
Re: crank failure
« Reply #12 on: April 04, 2008, 07:41:26 PM »
Just trying to stay positive. Good luck!
I hope they don't screw with you on the warranty either.
-Adam
d55dave
Re: crank failure
« Reply #13 on: April 06, 2008, 10:50:28 PM »
some pics.....
d55dave
Re: crank failure
« Reply #14 on: April 06, 2008, 10:51:19 PM »
and more.
73swinger
Blackstock, Ontario
Re: crank failure - update with pictures
« Reply #15 on: April 06, 2008, 11:05:50 PM »
holy cow man, BTW in the "broken crank 2" pic, the dark area isnt a new fracture, it's been arounf for awhile
nothingbutdarts
« Reply #16 on: April 06, 2008, 11:06:47 PM »
Glad the block is OK! I sure hope they help you out financially with a new crank!
Definate BUMMER though
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
   Bailey, Colorado
oldkimmer
« Reply #17 on: April 06, 2008, 11:12:28 PM »
.........WOW...Ive only seen that in chevies..... yes, my own...b 4 I seen the light.......kim........
farmington
Metro Detroit
« Reply #18 on: April 07, 2008, 08:12:56 AM »
If eagle doesn't do right by you go and see a metalurgist to have him determine why it broke and then go back at eagle.
When in doubt, Whip it out!
Dono
Want what you have..........
« Reply #19 on: April 07, 2008, 08:30:31 AM »
I am with you on that too.  It looks as if the crack was there about half way.
magart
Cape Breton, Nova Scotia
« Reply #20 on: April 07, 2008, 08:36:51 AM »
I had a Freightliner with a 500hp Detroit in it that did that-only at the rear. There was no noise, no miss, or anything-just a pulsation in the clutch pedal much like you'd get on the brake pedal with a bent rotor. We took the trans out thinking the center came out of the clutch, and once the clutch was off, the flywheel nearly fell on me. It was kinda strange to see that.
Beer in one hand, wrenches in the other.
« Reply #21 on: April 07, 2008, 09:26:44 AM »
ValiantOne
Western MD
« Reply #22 on: April 07, 2008, 09:41:36 AM »
Ive never seen a crank failure, although I hear about the weak point being that fillet area. It looks like this one runs straight through the fillet. In the experience of the board is this the common breakage point?
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
« Reply #23 on: April 07, 2008, 09:43:12 AM »
I've seen that exact same failure a few times.
wrflyer
« Reply #24 on: April 07, 2008, 08:21:35 PM »
 I have seen it many times especially at the front main. The weird thing is the bearings usually look like new.
Merrimack NH
strange246 strange2462000
« Reply #25 on: April 07, 2008, 08:34:05 PM »
Wasnt it Mopar Muscle that built a stroker 408 a couple years ago using an Eagle Crank and rods and the thing grenaded on the Dyno?
Ryan
Dr. Hunter S. Thompson
illfish
« Reply #26 on: April 07, 2008, 08:47:21 PM »
It almost looks like there was a temperature change when they did the casting.  That fault line seems to be an internal defect.  The burnished metal is where the pieces were scuffing and the dull is where the final crack occured.  I would bet that the burnished side of the crack was there for a while.  The lightening hole also has a witness mark through it that looks like a casting flaw/temp change.
B-onefan
Wild West Texas
« Reply #27 on: April 18, 2008, 11:24:04 AM »
Any Update's on this?
73 Duster
74 Duster
76Duster
67 Barracuda
68 Barracuda
68 Dart
69 Dart
72 Dart
78 Trail Duster
1999 Ram 1500 Sport QC 4X4
« Reply #28 on: April 18, 2008, 01:34:29 PM »
Thats exactly what I was thinking. The flaw was probably there since new.
moparteacher
« Reply #29 on: April 18, 2008, 03:47:55 PM »
Not pointing a finger, but over-tightened belts are known to break off cranks.
Moparteacher
Pages: [1] 2  All Go Up Print
